Logitech Wireless Mouse
Discussion in 'PC Gaming & Rigs' started by scookar, Mar 25, 2006.
  1. scookar
    scookar
    Jul 30, 2005
    117
    +4
    Just bought a new PC with the Logitech LX-700 wireless keyboard and mouse.
    One thing that the instructions don't really cover is whether you are supposed to put the mouse back in the docking station after each time you use it or only when the rechargeable battery has run out.
    Does anyone have the same keyboard and mouse? Do you only charge the mouse when the battery has fully run out? Will it affect the battery life if I put the mouse in the docking station when the battery still has life in it?
    Hope someone can help.
  2. Sarah Nya
    Sarah Nya
    I don't have the same model but its similar. I just put the mouse in to charge whenever I remember to be honest lol. It lasts ages between charges though.
  3. davet010
    davet010
    Jul 23, 2004
    385
    +10
    I only tend to do it every week or so. if the little light just beneath the scroll wheel shows red, then you definitely need to do it - and it takes a good while to charge up, too.
  4. semiskimmed
    semiskimmed
    Jun 30, 2005
    5,117
    Nottingham
    +259
    when i had mine, it used to last for days. i left it off the holder most often though. and it should take 10mins to fully charge up according to logitech, you might have a dodgy one davet010
  5. PhilNUK
    PhilNUK
    Dec 30, 2005
    881
    28
    +25
    I got the MX1000...
    got it last sunday, put it on charge for 10 mins and its got 2 lights left on it still with a lot of use with it this week.. very pleased with the mouse.
    Its best to only charge it when you need to charge it, much like a mobile phone I suppose..
  6. diamond_joe
    diamond_joe
    I got one of these and it normally takes about 4 days worth of my use to drain the batteries and to be honest i leave it in the charger only when i remember, takes a couple of hours to fully charge but is a pain to fit precisely in the unit at times:oops:
  7. Garrett
    Garrett
    Apr 21, 2001
    44,852
    2
    167
    The best thief you'll never see.
    +9,090
    It depends on how much you use the mouse as it goes in to a dormant stage when not in use bue I usually put mine back in the cradle at night but I have had 2 days heavy use out of mine but the red warning light has been flashing for about 3 hours before Iv been able to recharge it
  8. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    i have one of these and i tend to put it back in the cradle about once a week if i remember
    sometimes forget and get a warning on screen and haveto then put in after i have finished what i am doing
  9. scookar
    scookar
    Jul 30, 2005
    117
    +4
    Hmmmmmmm. Sounds like charginig once a week is the concensus.
    Does anyone else have problems with getting the mouse to fit with the contacts on the charger? It seems to be hit and miss sometimes. You have to really push the mouse against the back of the charger to make sure they connect.
    Or do I just have a dodgy cradle?
  10. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    no mine slips into the cradle no probs
  11. Chamber
    Chamber
    Jul 28, 2005
    32
    9
    Kaunas
    1st Rule: If u undrestand anything about PC u will never buy Wireless Mouse if u dont know why? just ask, ill tell u why :)
    2nd rule:Keep With Rule Nr.1
  12. bubble6
    bubble6
    I Have A Trust 250sp Optical Wireless Weird Thing Is Sometimes It Wont Work But If I Put My Keyboard Near It It Does Weird Eh?
  13. apolloa
    apolloa
    Jul 9, 2004
    6,220
    +1,350
    Why not then? What's wrong with the G7 Logitech?
  14. HMHB
    HMHB
    Nov 11, 2001
    27,406
    Nottinghamshire
    +6,285
    I've been using corldess mice for years without problems.
  15. Chamber
    Chamber
    Jul 28, 2005
    32
    9
    Kaunas
    becouse...man...wireless is not that accuracy as it should be, batteries and stuff... not worth...
  16. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
    Chamber, the LX 700 is very accurate for a wireless optical, and it has a built in rechargeable battery that doesnt take long at all to charge up!
    1st rule: If u undrestand anything about PCs... then read up on stuff before you give ill informed advice!
    Scookar, I have the LX-700 and have only recharged my mouse about 4 or 5 times since January... and I use it daily for games and general use... from about 2m away from the receiver. I havent had to replcae the keyboard batteries yet either.
    The red light will come on when it needs charged, but you still get a few more hours out of it before you notice it becoming slower and less responsive, then you just stick it on charge until the light goes off. Also, the battery should be re-charged before it's fully dead to get the best out of it... you can check it's remaining charge in the mouse section of the Logitech control panel.
    Hope that helps...
    Lee
  17. sleepyone
    sleepyone
    Jun 4, 2003
    736
    Glasgow
    +17
    I dont have a docking mouse, but my wireless logitech lasts about 4 months on 2 normal AA batteries. I get about 6 months out of the keyboard.
    And I have not noticed any drop in accuracy switching from wired to wireless.
    Im playing Half-Life2 at the moment and not noticed any problems. Saying that though HL2 isn't as much a twitch FPS as say BF2 or CounterStrike.
  18. AutomanUK
    AutomanUK
    I have this mouse and the MX5000 keyboard, how have you found the bluetooth hub mine can be a bit sporadic at times.:confused:
    P.s. I use the MX1000 fro BF2 and its great all those extra buttons come in very handy
  19. AutomanUK
    AutomanUK
    This might have been true 5 years ago but not now with all the new laser mice about. :thumbsup:
  20. Noggin1980
    Noggin1980
    Aug 2, 2005
    6,821
    +1,175
    As others have said you are completly wrong. Some of the new wireless mice (mouses?) are fantastic and every bit as good and accurate as a corded mouse.
    Years ago you would have been right but not anymore, especially not with the fantastic Logitech G7 gaming mouse.
  21. didgit
    didgit
    now that you mention it and without intending to highjack this thread...I have the same keyboard and mouse and they are very sporadic, I keep having to reset the bluetooth hub and botht he keyboard and mouse, once it's working is fine but it happens most time I switch my computer on after being off for a few days and it's driving me mad... I know most people leave their computer on all the time but I use my laptop so much that my main PC is switched for for days sometimes... does anyone knows a fix for this ?
