Logitech Squeezebox Controller : £49 delivered
Discussion in 'Music Streamers' started by amcluesent, Jan 5, 2012.
  1. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Use the following code to bring the price down to just £49 delivered - b7b7fyuw9
    Squeezebox
    And it works with all Squeezebox players, not just Duet Receiver.
  2. mr gothic
    mr gothic
    Aug 25, 2002
    1,594
    leigh
    +51
    hi
    might sound daft i have the classic would the screen be blank on the remote when used with the classic
    cheers
  3. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    You would have album art on the Controller (if available) and the track info as shoen ob the Classic's display
  4. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,843
    W.Mids
    +190
    Does this work with the touch ?
    Not clear on their website
    *Works with Logitech Squeezebox Classic, Logitech Squeezebox Receiver, and Logitech Transporter network music players.
    Cheers.
  5. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Yes, the Controller will work using either the embedded Media Server in the Touch or with a full Media Server and the Touch as a player.
  6. PhilCTTE
    PhilCTTE
    Aug 28, 2001
    1,843
    W.Mids
    +190
    At that price its pretty tempting.
    Only just played with the touch last night and as yet am only using the internal server. And I've found, whats been reported elsewhere, that its flaky and not upto the job. I've attached a USB external HD (Western Digital) and it dropped out constantly playing 96/24 material. And its also not exactly quick at browsing my library. So it looks like a new PC server config for me, or a beefy NAS. And with that comes android apps for using my smart phone , so not sure yet how good these are. £49 might be worth a punt.
    Straight out of the box comparing laptop foobar 2K usb isolator into the MDAC to Touch optical/coax into MDAC, I'm still prefering the laptop combo. Convenience wise its no contest and the Touch wins. I just need to squeeze (excuse the pun) a little extra quality out of the Touch. External PSU for starters (so its been reported)
  7. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
  8. pstree1
    pstree1
    Oct 21, 2009
    great spot, wish i had seen it earlier, looks like the code has expired now:(
  9. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,844
    +7,089
    Back to £49 with no codes required:
    Squeezebox
