Question Logitech K400+ & K830, compatible with WebOS?
niqen
As I see it the K380 won't work. It's either the K400+ or the K830. Are both of these compatible?
I know K400 is listed as compatible, and as such the K830 should be too. Can anyone confirm this?
Planning on connecting the keyboard directly to my C8 OLED TV.
Looking for a compact and somewhat decent looking keyboard with a pad. Open for suggestions if these won't work.
two2midnight
K400 plus unifying thing plugged into USB works on my E8.
niqen
Cool. I expect it is some limited support for different apps, but is it adequate enough for the simpler things? Could you in example basically do everything with the keyboard and ditch the remote, or is it needed every now and then? Thanks for your input
