Question Logitech Harmony One with Apple TV 4K
Discussion in 'Home Cinema Control & Remote Controls' started by CatManDo, Sep 5, 2018.
  1. CatManDo
    CatManDo
    Nov 5, 2003
    1,845
    South Yorks
    +253
    Hi all,
    Just got a new Apple TV, have added as a home cinema PC.
    All appears to be working however, when switching the activity off, the Apple TV appears to switch off but then comes back on a few seconds later.
    Also when starting the activity, the Apple TV starts with music playing, this is listed in the activity as:
    Apple Apple TV is set to "FrontRow"
    but I can't get rid of it!
    Any help would be appreciated.
    Thank you!
  2. Flashy
    Flashy
    Apr 20, 2006
    3,281
    +1,132
    I had this with mine and can’t quite remember how I solved it. Won’t be able to check on My Harmony until the weekend but will try to remember.
    It was something like making the power-off command a series of ‘presses’. From memory, it was something like one of Menu to exit whatever was playing, one of Home to go to the home screen, a long press of Home to bring up the sleep screen and, finally, one click of okay/main button to confirm the sleep.
    Caveat: I think if you go to the home screen while music’s playing it’ll carry on playing, and may resume when you turn it back on. The only way round that might be to pause, as if you include the pause as part of the power-down process it could end up starting music/video.
    Not sure whether that’s helpful or not. If not, I’ll try to see how I’ve got mine set up when I can.
  3. CatManDo
    CatManDo
    Nov 5, 2003
    1,845
    South Yorks
    +253
    Thank you, yeah if you oculd share you settings whenever you get the chance that would be appreciated.
  4. RobTi
    RobTi
    Dec 11, 2003
    2,603
    Hamilton
    +151
    Another who would be interested in the power off option, at the moment I have the atv going to sleep after 15 minutes to get round this
  5. mikelj
    mikelj
    Sep 4, 2006
    2,772
    Chorley, Lancs
    +484
    I just set my ATV4k to ‘always on’ as it doesn’t consume much power anyway and choose ‘there are no power buttons’ in the Harmony device power menu.
    It’s quite handy as the ATV just reverts to the screen saver and will resume at whatever you where doing last.
  6. Flashy
    Flashy
    Apr 20, 2006
    3,281
    +1,132
    Sorry for the delay. Just checked and it’s actually for the third-gen Apple TV. Sorry. But it should still work. I think...
    In Devices, the Apple TV’s power-off is set to be done with more than one button. Then:-
    • Menu – 2-second duration
    • A delay of 900ms (My Harmony desktop software says 900ms; iPad app says 0.9s)
    • Play – 3-second duration
    It relies on a video or music being paused before powering off. I think it should work on the fourth-gen/4K models if it’s tweaked to...
    • Home
    • Delay of 900ms
    • Home – 5-second duration
    • Delay of 900ms
    • OK (or whatever the Harmony command for the Apple TV remote trackpad being clicked is actually called)
    The delays are probably overkill, but work for me. Fingers crossed it works for these, but apologies if not.
  7. CatManDo
    CatManDo
    Nov 5, 2003
    1,845
    South Yorks
    +253
    Thanks very much for that mate, will give it a go cheers
  8. Flashy
    Flashy
    Apr 20, 2006
    3,281
    +1,132
    No problem. Obviously after I posted it didn’t work properly for me, but fingers crossed!
  9. CatManDo
    CatManDo
    Nov 5, 2003
    1,845
    South Yorks
    +253
    ok I've made some progress.
    I'm using the older Harmony Software 7.7 with my Harmony One.
    I've set the power on options for the Apple TV to be 'Home'
    Power off is:
    Home
    Home
    Select
    However I need the second 'Home' command to be held for a few seconds, ie the button held down.
    I can't find where to do this in the software, power on is ok it's just power off I need help with.
