mikeplow1961
I'm severely disappointed with the setting up of this device and have already come close to hurling the bloody thing across the room several times.
Devices
LG pk590 tv
Dreambox DM800HD sat receiver
Onkyo HTX22HDX av receiver
XBOX 360
Revo HTPC with Chinavision CVSB-983 USB ir receiver
To be fair, set up of most things has gone okay but the IR receiver is a nightmare.
Using the Logitech software 7.7.0, add Media Centre Computer, Chinavision CVSB-983, it asks me to press power, play and 1 on the remote. But after synching the H One it has no effect on the pc whatsoever.
Using the Logitech My Harmony.com site, add the device, it asks me to press power, play and UP on the original remote. After synching, it 'does' control the pc but you cannot add any extra commands to activities and my Dreambox needs an extra Exit command at the end of the Watch TV sequence.
It seems that the two methods of updating the remote pull up different codes for the same listed device (CVSB-983). Mailed support but had no response as yet.
Can anyone help?
Devices
LG pk590 tv
XBOX 360
Can anyone help?
