Logitech Harmony One and Yamaha Parametric EQ Settings?
Toxteth OGrady
Can anyone give me pointers on how to include Yamaha PEQ settings on my Harmony One?
My AVR is DSP-Z7 but I believe the PEQ settings are common to most Yamaha AVRs. Once I have selected an activity (e.g. watch TV/Amp or watch BD/Amp) I would then like to use button(s) on the Harmony, at either activity level or device level, to select the different PEQs.
On the Yamaha remote this is achieved by MENU --> SETUP --> SOUND --> PARAMETRIC EQ --> PEQ SELECT and choosing between MANUAL, FLAT, FRONT, NATURAL and THROUGH.
I can't see how to do this in the Harmony app on my PC and I have searched here and the Logitech forums but haven't come up with an answer.
:cool:
TOG
logiciel
All controlling in Harmonys is done in Activities.
Any command that is on the original remote should be available on your Harmony.
If any commands are missing you "learn" then from the original.
Then you can make the settings manually the way you do with the original.
You also have the option to set up Harmony Sequences to send up to five commands on one button press.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
