Logitech harmony Elite backlight is not very bright.
JohnWB
I have just setup my new Logitech Elite and it's great exept the backlight is not very bright.
I have seen people say "Make sure you go into remote settings and increase backlighting to maximum" but when i go into remote settings using my iPad tbe backlight adjust is not there.
Do i need to be using my PC or should that setting be available on the iPad.
logiciel
Yes - Settings - Remote - Brightness.
JohnWB
logiciel
As would I, and did so in post #3.
JohnWB
Found the setting on the remote ok and adjusted the brightness to just what I wanted.
Thanks very much for all your help.
logiciel
You're welcome!
