Logitech 680's
Discussion in 'Desktop & Laptop Computers Forum' started by Synchro, Nov 18, 2004.
  1. Synchro
    Synchro
    Nov 14, 2004
    5,727
    Chester
    +1,408
    Anyone use them?
    If you do do you have any advice?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Z680s? Yeah, had a system for well over a year. What sort of advice are you after?
    There's only one minor annoyance, there's a constant low-level hiss out of all speakers which is in the power-amp stage and thus not affected by the volume control so I don't keep it powered-on when not listening to audio (it's inaudible when something's playing).
    Apart from that I think it makes a great PC sound system and at a pinch could do for HC use if one was on a tight budget .. it can get pretty lound without distorting, its' DD and DTS decoding is of course a big attraction when viewing DVDs.
  3. .Griff.
    .Griff.
    Feb 1, 2004
    951
    Walsall
    +74
    How do you have your's setup K? By that I mean what soundcard are you using and which connections?
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Audigy 1 (with the external connector box) using SPD/IF (coax I think). Very occasionally I use 6-ch discrete but for the life of me I can't think of when I need to. :)
  5. .Griff.
    .Griff.
    Feb 1, 2004
    951
    Walsall
    +74
    So if I'm using an Audigy 2 (PCI) I'd probably be best using the 3 * analogue connections?
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Since I can't remember why I have a 6-ch as well as the SPD/IF I can't say that's the best option, unless that is you don't have SPD/IF. I think it may be to do with some games, maybe I need the analog outputs?
    The main 'loss' you'll suffer is no DTS decoding, the Audigy of course does Dolby, so the only activity not open to you would be viewing DTS-only DVDs (unless your DVD player has DTS decoding in software).
  7. Synchro
    Synchro
    Nov 14, 2004
    5,727
    Chester
    +1,408
    What's the score with using optical output from livedrive? I tried this and it worked, but I don't know what kind of output this would allow in terms of decoding?
  8. Synchro
    Synchro
    Nov 14, 2004
    5,727
    Chester
    +1,408
    At the moment, I am using them as seperates, connected to my stand alone DVD player, via Optical connection, until I get my Entertainment PC setup in the Lounge (more on this later ;) )
  9. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    I too have this system & it suffers with this annoying hiss.
    Is there anyway to eliminate this using one of the various mains filters on the market?? Although I have heard this can be at the expense of quality whereby it filters out more than it should. :(
  10. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I don't think a mains filter would help, I think it's noise from the power transistors and inherent in their operation.
  11. mi_july
    mi_july
    the low level hiss was removed in a firmare update i remember reading somewhere, dont know if this is true though.
  12. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Interesting, not sure I see how an 'in the field' firmware update could be done though.
