Logik LCD TV & Sky
Discussion in 'LCD & LED LCD TVs' started by nig6, Jun 8, 2004.
  1. nig6
    nig6
    Jun 8, 2004
    341
    28
    Newcastle
    +36
    I've just purchased the Logik 27" LCD TV from currys and it works fine, but I can't get my sky remote to work with it. I've tried the codes on the sky interactive help but no luck, and sky tech support were useless!
    Any ideas?
  2. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Buy a OneForAll learning remote or Philips Pronto...?
  3. andrew markwort
    andrew markwort
    Jun 20, 2004
    1,156
    63
    +159
    I've got the same problem. I was told by the Sky helpline to contact Logik (has anyone found Logik's home address?). I've just found a code on the web - 0016 - but haven't had time to test it out.
    I thought about One For All or similar, but to be honest, I prefer the setup I've got (I find all in one controllers annoying because I'm always forgetting to change modality before pressing buttons, and more than once in the past I've tried to switch off the TV and ended up cancelling a video recording or similar).
    Great set, though.
  4. fozzy73
    fozzy73
    hi guys a bit of info i posted ona different link there is no specific code for a logik tv for sky remote to work the tv try the blink back feature http://www.satcure.co.uk/tech/digicode.htm this is the link and its near the bottom of the page
    good luck guys
  5. elmbeck
    elmbeck
    Sep 23, 2002
    347
    Avonbridge
    +10
    any update on a code for Logik LCD?
  6. nig6
    nig6
    Jun 8, 2004
    341
    28
    Newcastle
    +36
    In case anyone's stuck, the code is 1245 and is now working!
    Ian
  7. ltrover
    ltrover
    This code does not work for my Logik 27" LCD!
    Searched everywhere for alternative, but it seems there isnt one!
  8. tjxkeith
    tjxkeith
    Mar 8, 2006
    28
    3
    I need code for the 32" model some one posted here or DS code 111 but wont work for me on the latest sky+ or HD remotes.
    So bought a high tech universal Harmony 855 remote instead. Very expensive but works fine.
  9. tjxkeith
    tjxkeith
    Mar 8, 2006
    28
    3
    See my other post on this thread re Amoi. As sold by Currys/Dixion there web site should give suport think it was www.techguys.co.uk you end up on but they were no help, said sky coundt handle more modern remote codes.
    Took what with a bucket of salt as when programing a Harmony unversal remote after a few button presses there web site came back with various Amoi models to use,
  10. maltesenick
    maltesenick
    Jul 24, 2006
    I know this is going a bit off the thread but am hoping someone might help me. I've got a Logik LCXW19LN1 tv in our caravan and when I use the remote to reduce the volume to a "whisper" level, so I can carry on watching whilst my beloved "kips", it goes down to what I think is still way too loud a level and then the next "setting" is off! Is there any way of reducing/changing the relationship between the on screen volume "bar" and the actual volume of the sound heard from the speakers? PS. Pillows over the two speakers just makes the screen hard to see!!
