G
Gen R
I have the above DVD player and need the region hack code please. I have loads of Region 1 and Region 3 DVD box sets that I now cannot play on this device. Any help would be much appreciated. Thank you.
The first part is how to set it to multiregion, the second is how to check your new regional setting.
1. Power up
2. Open the dvd tray
3. Type in this code 1369, XXXX will appear on your screen.
4. Press 0 for multiregion, the digit 0 should appear, if not start again from the code 1369.
To check your region.
Press setup / general tab / press 1389. A new window will popup listing a few details includuing your new regional code. Press enter to exit.
