Quantcast
Logik L1HSTB12 firmware
MrDave123
Does anyone have a copy of the Logik L1HSTB12 firmware? Its a Vestel T7650 box.
Mines packed in! I've plugged it into the laptop via the scart to serial cable and it seems to be stuck in a loop of rebooting itself and is complaining about missing files... not ideal!
Cheers,
Dave
Futaura
Are you able to save the serial log to a file, and post the content here or via PM? I may be able to help you out.
MrDave123
Hi Futaura, slight delay on the reply.. sorry! :)
Yes, here's the log:
BCM97230B2 CFE v3.10, CFE core v3.23, Endian Mode: Little
VESTEL VERSION : v2.9
CFE initialized.
NO secure update starts
STARTUP variable not set
STARTUP env saved
UPDATE CFE
USB device matching <USB Disk> not found!
Fail CFE update
Kernel, rootfs, rw partition update fails
Loader:elf Filesys:raw Dev:nandflash0.kernel File: Options:ubi.mtd=rootfs root=/
dev/mtdblock9 [email protected] [email protected] libata.force=3
Loading: 0x80001000/5540352 0x80549a00/120576 Entry address is 0x80426470
Starting program at 0x80426470
Linux version 2.6.37-2.8 ([email protected]) (gcc version 4.5.3 (Broadcom stbgcc-4
.5.3-1.3) ) #6 SMP Wed Jun 27 17:34:38 CEST 2012
KERNEL VESTEL VESRSION 1.3
Fetching vars from bootloader... found 20 vars.
Options: enet_en=1 enet0_mii=0 enet_no_mdio=0 enet1_en=1 moca=0
sata=1 docsis=0 pci=0 pcie=0 smp=1 usb=1
Using 512 MB + 0 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a064 (Broadcom BMIPS4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 10000000 @ 20000000 (usable)
bmem: adding 192 MB RESERVED region at 64 MB ([email protected])
bmem: adding 200 MB RESERVED region at 512 MB ([email protected])
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00030000
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0x00000000 -> 0x00010000
0: 0x00020000 -> 0x00030000
PERCPU: Embedded 7 pages/cpu @81606000 s6656 r8192 d13824 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129536
Kernel command line: ubi.mtd=rootfs root=/dev/mtdblock9 [email protected] [email protected]
512M libata.force=3
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 110716k/524288k available (4327k kernel code, 413572k reserved, 897k dat
a, 184k init, 0k highmem)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
NR_IRQS:128
Detected MIPS clock frequency: 594 MHz (297.008 MHz counter)
Console: colour dummy device 80x25
Calibrating delay loop... 591.87 BogoMIPS (lpj=295936)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
USB0: power enable is active low; overcurrent is active low
USB1: power enable is active low; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource wktmr
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.15)
msgmni has been set to 216
io scheduler noop registered
io scheduler cfq registered (default)
Front panel module installing
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
console [ttyS0] enabled, bootconsole disabled 65) is a 16550A
serial8250.0: ttyS1 at MMIO 0x10406940 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406980 (irq = 67) is a 16550A
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 3.0Gbps
ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 41
ata2: FORCE: PHY spd limit set to 3.0Gbps
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 41
brcmstb_nand: NAND controller driver is loaded
Config internal EPHY through MDIO
No PHY detected, not registering interface:1
bcmgenet: probe of bcmgenet.1 failed with error -5
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 69, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 70, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
Wake up module installing
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
TCP cubic registered
NET: Registered protocol family 17
EBI CS2: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0x20, Chip ID: 0x76 (ST Micro NAND 64MiB 3,3V 8-bi
t)
NEW KERNEL
############SPARE AREA SIZE=16
####### ECC LEVEL = 4
brcmnand brcmnand.0: overriding bootloader settings on CS2
brcmnand brcmnand.0: was: 64MiB total, 16KiB blocks, 512B pages, 16B OOB, 8-bit,
BCH-4
brcmnand brcmnand.0: now: 64MiB total, 16KiB blocks, 512B pages, 16B OOB, 8-bit,
BCH-4
searching mtd name = brcmnand.0
Bad block table found at page 131040, version 0x01
Bad block table found at page 131008, version 0x01
nand_read_bbt: bad block at 0x00000120c000
nand_read_bbt: bad block at 0x000003650000
RedBoot partition parsing not available
Creating 5 MTD partitions on "brcmnand.0":
0x000000400000-0x000001400000 : "rootfs"
0x000000000000-0x000000400000 : "kernel"
0x000000000000-0x000004000000 : "rr"
0x000001400000-0x000003f00000 : "rw"
0x000000000000-0x000004000000 : "entire_device"
EBI CS0: setting up SPI flash
spi_brcmstb spi_brcmstb.0: 1-lane output, 3-byte address
4: ----->>>> Number of parts
----->>>> name: cfe, size: 80000, offset: 0
m25p80 spi0.0: found m25px16s0, expected m25p80
m25p80 spi0.0: m25px16s0 (2048 Kbytes)
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000080000 : "cfe"
0x0000000a0000-0x000000200000 : "nvram"
0x000000090000-0x0000000a0000 : "macadr"
0x000000080000-0x000000090000 : "id"
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
ata1.00: ATA-8: WDC WD10EURX-63FH1Y0, 01.01A01, max UDMA/133
ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 16384 bytes (16 KiB)
UBI: logical eraseblock size: 15360 bytes
UBI: smallest flash I/O unit: 512
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA WDC WD10EURX-63F 01.0 PQ: 0 ANSI: 5
############ sdp->host->unique_id 1
sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 0:0:0:0: [sda] 4096-byte physical blocks
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO
or FUA
sd 0:0:0:0: Attached scsi generic sg0 type 0
UBI: VID header offset: 512 (aligned 512)
sda: sda1 sda2
UBI: data offset: 1024
sd 0:0:0:0: [sda] Attached SCSI disk
ata2: SATA link down (SStatus 0 SControl 320)
UBI: max. sequence number: 852
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 16 MiB
UBI: number of good PEBs: 1023
UBI: number of bad PEBs: 1
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 89
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 159
UBI: total number of reserved PEBs: 864
UBI: number of PEBs reserved for bad PEB handling: 10
UBI: max/mean erase counter: 1/0
UBI: image sequence number: 1938944788
UBI: background thread "ubi_bgt0d" started, PID 440
VFS: Mounted root (squashfs filesystem) readonly on device 31:9.
Freeing unused kernel memory: 184k freed
starting pid 446, tty '': '/etc/init.d/rcS'
Mounting virtual filesystems
Starting mdev
* WARNING: THIS STB CONTAINS GPLv3 SOFTWARE
* GPLv3 programs must be removed in order to enable security.
* See: Frequently Asked Questions about the GNU Licenses - GNU Project - Free Software Foundation
Configuring eth0 interface
eth0 cable plugged in, powering up
Configuring lo interface
Starting network services
UBI: attaching mtd3 to ubi3
UBI: max. sequence number: 3904678
UBI: attached mtd3 to ubi3
UBI: MTD device name: "rw"
UBI: MTD device size: 43 MiB
UBI: number of good PEBs: 2751
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 2751
UBI: number of PEBs reserved for bad PEB handling: 27
UBI: max/mean erase counter: 2140/1419
UBI: image sequence number: 1539454762
UBI: background thread "ubi_bgt3d" started, PID 484
UBI device number 3, total 2751 LEBs (42255360 bytes, 40.3 MiB), available 0 LEB
s (0 bytes), LEB size 15360 bytes (15.0 KiB)
UBIFS: recovery needed
brcmnand brcmnand.0: uncorrectable error at 0x2747e00
UBI error: ubi_io_read: error -77 (ECC error) while reading 1024 bytes from PEB
1233:15360, read 1024 bytes
UBIFS error (pid 503): ubifs_recover_leb: corrupt empty space LEB 1025:14336, co
rruption starts at 808
UBIFS error (pid 503): ubifs_scanned_corruption: corruption at LEB 1025:808
CPU 1 Unable to handle kernel paging request at virtual address e00e5000, epc ==
8024b600, ra == 8024b614
Oops[#1]:
Cpu 1
$ 0 : 00000000 30008b00 00000009 804c0000
$ 4 : af5c1bad 0000004e af5c1a1f 804ba8b0
$ 8 : fffffffd fffffffe ffffffff fffffffb
$12 : 8044e4f0 af5c19b8 0000000f 00000000
$16 : 00000035 af5c1b78 00000083 00000020
$20 : e00e4fe8 00000006 e00e5000 00000008
$24 : 00000002 8027d0c0
$28 : af5c0000 af5c1b10 804b834c 8024b614
Hi : 00000000
Lo : 00000008
epc : 8024b600 hex_dump_to_buffer+0x37c/0x3d4
Not tainted
ra : 8024b614 hex_dump_to_buffer+0x390/0x3d4
Status: 30008b03 KERNEL EXL IE
Cause : 00800008
BadVA : e00e5000
PrId : 0002a064 (Broadcom BMIPS4380)
Modules linked in:
Process mount (pid: 503, threadinfo=af5c0000, task=afd005c8, tls=775d4460)
Stack : 00000020 00001b40 000004c0 804ba8b0 00000000 00000002 00000001 804a27a0
00000020 00001b20 000004e0 af5c1b78 000004c0 00000002 804a1864 804a27a0
00002000 8024b748 af5c0000 804a1864 804a27a0 000004a0 af5c1b78 00000083
00000001 80500000 30303030 30303030 30303020 30303030 30302030 30303030
30203030 30303030 20303030 30303030 30303030 30303020 30303030 30300030
Call Trace:
[<8024b600>] hex_dump_to_buffer+0x37c/0x3d4
[<8024b748>] print_hex_dump+0xf0/0x190
[<801e71c4>] ubifs_scanned_corruption+0x90/0xa8
[<801f5dd8>] ubifs_recover_leb+0x740/0x75c
[<801e7d80>] ubifs_replay_journal+0x4fc/0x11dc
[<801de868>] ubifs_mount+0xe88/0x1400
[<800c6f20>] vfs_kern_mount+0x64/0x1b8
[<800c70c8>] do_kern_mount+0x44/0x120
[<800e65b4>] do_mount+0x1b0/0x7cc
[<800e707c>] sys_mount+0x84/0xf0
[<80011f7c>] stack_done+0x20/0x40
Code: 02502823 26d60004 2467a8b0 <8ec20000> 03c03021 26b50001 0c091fc7 afa2
0010 02b7182a
Disabling lock debugging due to kernel taint
/etc/init.d/rcS: line 131: 503 Segmentation fault mount -t ubifs /dev/ubi
3_0 /root
ubidetach: error!: cannot remove ubi3
error 16 (Device or resource busy)
ubiformat: error!: please, first detach mtd3 (/dev/mtd3) from ubi3
ubiattach: error!: cannot attach "/dev/mtd3"
error 17 (File exists)
eth0 cable unplugged, powering down
Does that help at all? Thanks for the help!
Cheers,
Dave
Futaura
Yes and no. A quick glance, comparing to a working box's log, shows that everything is apparently normal until after the "UBIFS: recovery needed" line - normally, you should get "recovery completed" directly after that. What follows in your case is that it indicates that the flash memory is corrupt which is not a good sign :(. I have not encountered such an error before, but there is one thing that I am aware that might resolve this - essentially a full flash update. Depending on whether the flash ram on your box is faulty or not, this could get your box working again or completely brick it. Check your PM.
ptrg
Is there any way to write firmware from the box on USB?
I've got one of these with 1.57 (even though such version isn't mentioned anywhere on internet) and another one with 1.49.
I would like to update the latter one but there's nowhere to download anything newer than 1.49.
Futaura
That's because 1.57 is an unofficial test version - 1.49 is the latest public release version. I have had 1.57 for a while now, and would love to make it available for download from my site, but without Vestel's consent I am unable to do so :(. 1.57 certainly fixes a fair few bugs that are present in 1.49 and is stable in my experience.
May I ask where you got the 1.57 box from and is it Logik branded?
To answer your question, there is no simple way to export the software, but if you are familiar with telnet and Linux, it is possible to copy the software off and manually install it into one of the application software slots on another box.
ptrg
Are you sure 1.57 is still unofficial?
I've got 1.57 printed on the official sticker underneath, the same one as on the 1.49 one. It is Logik.
I've got it as second hand on a carboot sale and there are recordings on it as old as Jan 2015 so it must have been around for a while.
Unfortunately I don't know much about Linux and telnet :(
I thought it would be as easy as on Ferguson Ariva boxes where it's a standard option in the menu to dump it on USB or update from it.
BTW Is it normal for this model to boot up for ages and load the library very slow as well?
Futaura
That's very interesting - I was involved in testing 1.57 starting October 2014. If 1.57 was deployed soon after that at factory levels, it makes me even more frustrated that the update cannot be passed on to end users. The only other explanation is that you purchased a test box. I shall try to find out more - with regard to 1.57 being an unofficial test release - that is what Vestel told me.
The more you have in the library, the longer it will take to display the library and the longer it will take to boot, so yes it is normal. You could switch off low power mode to avoid bootup delays, although this would be particularly inadvisable with 1.49 (because the HDD could fill up with timeshift buffers, for example).
ptrg
Any news about the firmware?
Is 1.57 still unofficial or is it available somewhere? Or maybe something even newer than that?
Futaura
Unfortunately not. I pushed really hard, last year, to allow v1.57 to be downloaded from my site, but Vestel were reluctant. I have been told many times that v1.57 has not been officially approved. It's an obsolete model now, so will never be approved, I guess.
I never did get any explanation as to how a Logik T7650 apparently shipped with v1.57 on it :(.
sickboy83
Hello folks, sorry to reopen this old thread, but i think the problem is related.
I recently moved to Italy and brought the Logik T7650 with me, but when I do a channel search (or even a first time installation) the channels don't come up in order. They start from 800 and are in alphabetical order. Also, it doesn't let me change the language. I've updated the firmware (I got the 1.49 now) but to no avail. Any idea how to solve this? Any help would be appreciated :)
Fred Smith
You wont be able too, non Freeview and some duplicated channel are automatically stored in the 800's.
sickboy83
Thanks Fred, I was afraid it was so.
Is there any way to flash a different firmware that would accept a different country? Or a way for me to change the channel number?
The box doesn't even let me change language.
Also, it seems to me that the box is only storing a hundred channels (from 800 to 899), but with an italian set top box I get 400+ channels between tv and radio.
I'd be upset to have to basically bin the box :(
Fred Smith
Try asking Futaura (above) if Italian FW is available.
Futaura
If there is Italian firmware, I don't have it :-(. Earlier models had European software (country selectable) which did not work in the UK - the UK always has special builds that are UK only.
Your only hope is to try and get an answer from Vestel, unless there are forums in Europe that discuss the T7650.
Trending threads
