Loftbox/sky+/sky
Discussion in 'Sky Digital TV Forum' started by Pancozi, Oct 24, 2005.
  1. Pancozi
    Pancozi
    I'm about to have skyplus installed.Currently I have sky distributed to 4 rooms via the traditional loftbox layout. I have seen on TVLink website that they do a "skyplus combiner" which combines the return feed from a sky box and a skyplus box which can be distributed to all 4 rooms.
    Does anyone have one or these and if so does it work OK. Is PQ OK?
    Will look a bit wierd in the lounge with both a sky & sky+ box but if they both work around the house I can live with it!
  2. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    I have sky+ box in lounge and a standard 4 way amplifier (non powered ) in loft. I have two cables come down from dish to sky+ box, then cable from RF2 back up to loft and into amplifier, then 4 cables which go to 3 bedrooms plus kitchen and I have magic eyes in all rooms and can use all SKY+ remote buttons in which ever room I like. PQ is fine throughout, sound is only mono through coax.
  3. kingtj
    kingtj
    Mar 11, 2005
    374
    Coventry
    +10
    thelurch, what standard 4 way amplifier you using ?
  4. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    I will go up in the loft and have a look as I cant remember exactly!
  5. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Right, its a white box, on the top it says T140 4 way signal booster TV link
    On the back it says Global communications UK ( globalcom.co.uk ) and tvlink.co.uk.
    Hope that helps.
    Its probably not anywhere near the best but its fine for me!
  6. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    I've installed this system and it works perfectly... I wouldn't recommend RF on too big a screen, but for secondary viewing it's fine... Each box needs to be set to a different RF channel via the installer menu and you'll obviously need both Sky and Sky+ remotes in each room...
  7. Pancozi
    Pancozi
    Just to clarify, I am planning on thelurch setup (loftbox instead of amplifier - but shouldn't make any difference) with an additional skybox also connected to the same upfeed and distributed to all rooms.
    Anyone know where I can get 4 new cheap skyplus remotes?
    SimonO, is PQ as good as sky only in other locations?
  8. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
  9. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Do you mean on of these:
    http://www.tvaerials.com/product.aspx?productid=439
    Yes i've used them in the past without any problems.
  10. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    24,000
    2
    The Fylde Coast
    +14,009
    Unless you are taking out the extra room sub, or you get an extremely helpful installer, a standard Sky+ install will only get you two Sat cables into your lounge. I know I had one done recently and wanted the 2 x extra LNB outlets to be wired through "for future use". No way Hose A. Hose B wasn't an alternative either.
    And this is your planned set up?
    Combiner Plus Diagram
  11. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    My extra cabling I did myself after sky had been, I was replastering the whole house so hiding cables wasnt a problem. Sky wouldnt do this as part of their initial installation.
    As for cheap sky+ remotes, try ebay ,they often go for between £10 and £15 and some come with the TV link magic eyes
  12. Pancozi
    Pancozi
    I was hoping my charm offensive may get two additional cables installed for skyplus. Spoke to engineer today and explained what I want - he seemed OK about the install. Will see tomorrow when he arrives.
    Will have to keep fresh coffee brewing in the background as an incentive.
    If it does go OK will I need freesat card for original box?
  13. Pancozi
    Pancozi
    UPDATE:
    Pace PVR3 installed today. He left the original box connected aswell as I requested - good man! so it looks like I'm in business.
    Now all I need is this "Plus Combiner" , a freesat card and a handful of remotes
    Should be ready for XMAS (2006) :)
  14. strech
    strech
    :clap: could you still do this with 2 sky+ boxes 1 in livingroom other in bedroom (pace 40 upgraded to 120) and (thompson 160) and then feed the outputs to 2 bedrooms and kitchen as the remotes would be the same I cant see this working or is there a way ? only got pace at momment feeding 3 other tvs 160 in a few weeks
    KIT
    4 way loft box
    3 magic eyes
    4 sky + remotes
    any help guys :thumbsup:
  15. Pancozi
    Pancozi
    UPDATE:
    this system works perfectly! Why dont more people use this instead of multiroom?
    I can watch Sky and sky+ in 5 locations around the house. Granted its only skys free channels which arent up to much but even if you took out multiroom surely this way you could watch anything anywhere!
    PS- Strech, the two sky+ units can be given different RF channels but dont know how the remote situation would work!
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,344
    +1,218
    it cant but there is away around it need learning remote and RF extender (but a real pain!) like harmony H895, anyway anyone terll me how to get into installer menu? services,0,1,select isnt workung Pace sky+ V3 BTW
    EDIT its services, 4, 0, 1, select
