Question Loftbox 4 way wiring query
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Paul2408, Feb 13, 2018.
  1. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    I hope you can help. I have an apartment with a communal aerial - satellite (1 feed), terrestrial and FM which I think comes into my apartment comms box as one feed. I have a loftbox in the same location
    At the main tv there is a triplex with sat, tv and return. There are 2 other tv points - just single coax points. There is also a fm point near to the cabling for whole house audio
    My question is the wiring of the loftbox looks odd as it seems to have a separate modular triplexer in the same location - I have attached a drawing the labelling is as per the cables. Why is it wired like this and also I wonder if the labels on the lounge and feed maybe the wrong way round ?
    [​IMG]
    Do I need it wired as it is - I would like to tidy up if possible to make space in the comms box for cat5 patch panel and router as it was designed for - home network sciences comms panel
    The installer is long gone and current maintainer of communal system not helpful
    Any help would be great
    Paul
  2. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,596
    Cheshire
    +1,059
    Not seeing get the image (on a smart phone anyway)
    Inspired guess.. the return is intended for you to add a TV picture from say a sky or satellite box in the main lounge. . The main rf comes down that on coax with the sat & what sounds like fm/dab .. it should then go through a sky/ Sat box & the rf output back up the return with the modulated picture from the box so it can be distributed to all tvs
    If you don't do that you can use a small loop coax between tv & return to keep the rf going to the other tvs to get freeview
  3. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    I have now attached file
  4. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    Thanks for any ideas
  5. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,596
    Cheshire
    +1,059
    How are the two sat connections wired together from the 1st wall plate to the second wall plate?
    The overall diag doesn't quite look right.. is there something missing or I've missed.. the feed coming in from the dish / aerial for example .. the wiring on the return?
  6. TJT1
    TJT1
    Jul 29, 2011
    4,263
    East Sussex, UK
    +961
    I think it's a single input from the communal system coming in at the top of the page into what looks like the 'living room' connector between the Sat and the DAB connectors. Still a bit weird though. Which is pretty much what the OP has said.
  7. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    Thanks all. I think I will check the cables come from and go to where the labels on them say they do. Could the triplexer that is next to the loftbox be splitting the incoming feed from the communal system to go into the loftbox to be combined into single lead to go to lounge triplexer ?
  8. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    Hi all
    Does my thought above make sense ?
  9. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,596
    Cheshire
    +1,059
    It does if you are referring to the signal for Freeiew. .You can split that, but you can't easily split satellite, so if that's been done, you need to sort that out. You or they can join satellite with freeiew (to save a cable run really) & with dab/FM hence the triplex plate to split it again... if that's helped .. but the diag didn't look right re the above
  10. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    Thanks having looked again I think the communal feed into the apartment is a single cable which must contain dab/fm and terrestrial/free view and satellite. This then goes into a triplexer that is in the same cupboard as the loftbox with cables coming off that into the loftbox as per the diagram
    I assume this is coming from a switch located in the comms room for the building
    Is this normal approach ? Would a photo help
  11. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,596
    Cheshire
    +1,059
    It makes more sense, that that triplex wall plate is in a cupboard with the rf distribution amp & not in a lounge so the Sat isn't split ..
    but the diag still doesn't look quite right. The main feed coming in goIng into the rf amp labeled lounge ?
    I can see it working if the main feed (from the main multiswitch) goes to the triplex wall plate, the split sat feed then sent to the lounge as is, the rf sent to the rf distribution amp and so all tvs get freeview & maybe dab FM
    Or if the rf amp has its own diplex to use that so it takes sat & rf & splits it in the lounge
    Or.. as there's a return, the Sat & rf are sent to the lounge, split via the wall plate's diplex, the rf loops through the rf on say a sky box or sat box with a modulator like a TM .. then sent back to the rf amp on te return via a 2nd coax though ..then all rooms receive freeview & the channel sky or a sat box is on (& maybe dab fm)
    I think the diag might be either wrong or its wired wrong
  12. TJT1
    TJT1
    Jul 29, 2011
    4,263
    East Sussex, UK
    +961
    I think that's what Paul suspects.
  13. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,596
    Cheshire
    +1,059
    Maybe someone changed things round at some point . With rf you can wire things not quite right and with the nature of rf signals .. it still kinda works sort of ..
    @Paul2408 .. what make model is the loft box
  14. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    Global loftbox 4 way
  15. Paul2408
    Paul2408
    Feb 13, 2018
    Manchester
    Now worked out that the cable marked feed is actually the one going to the triplexer in the lounge so that’s correct the triplexer in the cupboard adjacent to the loftbox I assume is splitting the feed that then goes into the loftbox
    Does this make sense and is that triplexer required or is there another way to deal with the incoming feed and linking it to a loftbox to distribute it into the apartment
  16. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,596
    Cheshire
    +1,059
    if it's a good quality triplxer wall plate then it will do the job, you can use inline gear but you've already got what you need, the only improvement would be all f connectors which is better & if the existing wall plate triplexer is not well screened... you can make it x amount cleaner but I think you are already there.
    The Global RF amp is a good quality one, I use them.
