Loft Distribution - new Sky+HD wifi enabled box - I/O Link
Discussion in 'Sky Digital TV Forum' started by hrichardson81, Feb 3, 2014.
  1. hrichardson81
    hrichardson81
    Feb 3, 2014
    2
    Hi I am hoping someone can help me.
    I have a new(ish) house that was fitted with a loft distribution unit. I have my current Sky+ box running through this unit which enables me to have my TV located on a different wall in the lounge (as all of the wiring is run through the walls to the distribution unit).
    My Sky+ box has stopped working (critical fault apparently). Sky have sent me a Sky+HD wifi enabled box which doesnt have an Aerial port. I have then read multiple forums and found that this is common, I require an I/O link.
    Can anyone tell me if this I/O link will work? I'm hoping that I will literally just replace the wires from the back of my old Sky+ box with the wires that go into the new Sky+HD box?
  2. hrichardson81
    hrichardson81
    Feb 3, 2014
    2
    Also, I'm also assuming that I will have to forgo the HD as I can't run a HDMI cable from the SKY+HD box to the TV?
  3. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    In theory that is what should happen as the IO link will send the signal via the coax cable like before.
    Yes without a HDMI connection between your skybox and the TV you will not get HD TV.
  4. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
