loft aerial
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jelly, Nov 30, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    is there any particular reason why an aeriel in the loft would woudnt work
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    for freeveiw???
    Yeah the roof is in the way! if you have an excellent signal it will work if not you get lots of break up if signal is weak then you just get red dots!
  3. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    no just for analogue
  4. Brian110507
    Brian110507
    Mine in the roof works fine for normal TV viewing, depends entirely on signal strength in your area, if you have a strong signal an aerial in your loft is every bit as good as an aerial on your roof, a few slates or tiles do not make that much difference,
  5. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    Beejaycee,
    I beg to differ, had a massive FM aerial in the loft and could barely get anything, once on roof barely had any hiss at all - I wouldn't put my aerial in the loft unless I had no choice.
  6. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I have a loft aerial and it works perfectly for analogue and Freeview. I live in Bath and get the signals from the Mendip transmitter (some 15-20 miles away). My Sony Freeview box shows good signal strength and no quality problems.
    I'm sure that given the choice roof is better, but I bought a house which already had a loft aerial, and as it works fine, will stick with it.
    Mark
  7. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    Where I live, 20 miles from the Dover transmitter, loft aerials installations are useless. Its external or nothing down here.
    Thats a poor analogue signal for you.
    Digital is even worse. :thumbsdow
  8. Brian110507
    Brian110507
    Brox, I did say it depends entirely on the signal strength in your area, My VHF radio in the kitchen gives excellent reception on a single rod aerial extended to about 750mm, and the signal has to pass through at least two 250mm thick brick walls, in my bedroom I do have a 300ohm aerial, pinned to the inside of my wardrobe !! again good reception with the signal passing through at least one wall and the wood of the wardrobe. Thats with VHF radio, a UHF television signal will pass through almost anything witness the thousands of people who happily watch TV from a set top aerial buried in the lounge or at best in a bedroom or flat. If UHF did not pass through brick walls the original analogue mobile phones would have never got of the ground if you couldn't use them indoors!!. I am therefore making the point that UHF signals will pass through the 5 - 10 mm of tiles/slates on your roof without noticing that their there and if you get poor reception I believe it has more to do with the position of the aerial than the fact that it is in the loft. I believe it's allways worth just trying an aerial in the loft first first you might be surprised, it's then very easy (although more exspensive and difficult with the possiblity of causing structural damage to your house) to move it outside if you are not happy with the picture.
    But it does depend on signal strength, if like me you live less than 20 miles across relatively flat terrain from the Crystal Palace transmitter then no problem
  9. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    I live in Ramsgate and I have a loft aerial for the bedroom TV and it works fine on all channels. I live about 20 miles away from Dovers Transmitter and I have no problems. Where do you live Archie I assume it must be nearer Hastings direction??
  10. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    I live in Margate- next door to Ramsgate. Its interesting that your signal is that good and mine is so bad. You have good reception on all channels? Is that analogue or digital though?
  11. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Hi archie, the aerial in my loft is purely for analogue only. Dont think i would get away with it for digital. Is yours analogue??
    EDIT: Thinking about it I think that Ramsgate is higher than Margate, think thats is the reason why the Invicta transmitter for Thanet is in Westwood purely for the fact that is the highest point. Just a thought??
  12. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    I've had to install a 52 element largear aerial myself to improve things for the digital reception. It's outside the house up on the chimney. It does a good job considering how low the signal is. But passing traffic is the main problem for me at least with impulsive interference causing the digital picture to break up.
    Ramsgate is also very slightly nearer Dover so this might explain your better reception.
  13. cupcake
    cupcake
    I live in Hammersmith, and have my aerial in the loft. My Sony freeview box had been working pretty much flawlessly with good strength and signal quality. Bizzarely though, on tuesday night, channel 5 reception was attrocious....very poor signal quality. Wasn't home last night to see if there was an improvement. Any ideas what might be going on?
  14. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Another factor is the kind of insulation you have. Many roofs nowadays are insulated with stuff like Cellotex which is thick foam with silver material on the sides and it's often fitted under the tiles, all the way to the ridge. This can cause signals to bounce all over the shop.
