Loft Aerial for Freeview?
Discussion in 'Freeview & YouView' started by Blu Ray, Dec 19, 2004.
  1. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Hiyas,
    I live on a hill and opposite Winter Hill transmitter mast, therefore I can practically receive transmissions by hanging a sock out of the window.
    Having said that, I am wondering if I would be able to receive Freeview OK by just using a loft aerial. Has anyone trried this who lives near a transmitter?
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I live miles from Crystal Palace and my loft aerial works just fine. So does my mums and thats 50 years old [may have been replaced for colour TV?]. Is there a problem with loft aerials when close to a transmitter?
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,130
    Rainham Essex
    +2,392
    Well I live in a flat that is miles away from a transmitter. I have a loft aerial that is years old and has just about everything wrong according to the ideal install. But I still get very good reception of Freeview.
    This just shows that there are no hard & fast rules with old aerials or even where they are installed. You just need to try it and see if it does work.
    Mark.
  4. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    I live about 17 miles from Winter Hill (as the crow flies) and have a loft aerial. I am also in a valley behind a further range of hills.
    Reception is good most of the time, but weather and mornings can affect signal quality. I have a Televes DAT45 and mast head amp in the loft.
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,815
    Somewhere in South Yorkshire
    +5,022
    30 miles from Emley Moor - fairly good line of sight. Good totally glitch-free reception on a loft aerial and an old On-Dig box.
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Puttting an aerial on the roof doesn't only increase its height, it also means that the roofing material will shield the aerial from interference sources within the house. The amount of shielding you get depends on what sort of roofing material you have. Digital TV is fairly susceptable to interference, causing pictures to pixellate and the sound to break up. It's often worth trying out a loft aerial on Freeview before spending money on a roof aerial - in many cases it will be sufficient.
    Where I am - N. Cambs - over 30 miles from Sandy Heath, I need a high-gain aerial with a masthead amp to provide sufficient signal for 2 TV's.
  7. gdickin2
    gdickin2
    Nov 29, 2002
    75
    Preston
    I live in Preston and got fairly poor reception throught my 'digital Tv' aerial when in the loft. Channel 5 was particularly affected and largely unwatchable. Most other channels would seem to fall apart after 9:00pm aswell. I have now moved the aerial outside and the signal strength has increased considerably and all channels are now watchable.
    If its no hassle to you then I would go for the outdoor option.
  8. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Thanks guys, think I'll try the loft one first on a sale or return basis. have to wait till New Year now, though ;)
