Loewe Xemix 8122DD
G
goldfish14
I've purchased the Loewe Xemix 8122DD a month ago. My Dealer kindly gave me the Mulit-region hack that works fine. Any one wanting the instructions well here they are. You can select which region you want, normally region 0 works with most DVD's. Player is a tad noisy when playing but mine is hidden away so I dont hear it. Excellent Picture & sound quality and with DVD audio as well as being able to control this player directly through a Loewe Television.
Here is the Hack
make sure there are no dvd's in your player
1 press pause on the remote
2 enter 314159 - you should now see a region change screen, if you don't try enetering 1 and 2 again but do it faster !
3 press 0 for region free, 1 for region 1, 2 for region2 (we always change to 0 - seems to work for all dvd's)
4 press pause on remote
5 power off player
And thats it
Happy playing
65-inch LG C1 Review coming soon to AVForums
