Quantcast
Loewe Xelos 32 LED
Sounds Familiar
I’ve just replaced my Loewe Xelos 32 inch CRT with the equivalent Loewe 32 inch LED.
I have on issue with the Scart connection . I feed the scart with a Multi region DVD.
When playing Region 2 DVDs it gives the native output 576i 50 component RGB(PAL), and the Xelos has no problem, but when I Play a region 1 the output is 476i 60 component (NTSC), the set seems to have problem adjusting scans to cope. I’m surprised as it worked perfectly on the CRT.
Any help on this matter will be much appreciated. Gary
:lease:
