loewe what?
Discussion in 'General TV Discussions Forum' started by keyser, Jun 17, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    I don´t now anything about the Loewe TV´s, but can I get a model that is 36" or more, flat screen and takes progressive scan signals.. .. what do you recomend in the Loewe range that will compete with the pixelplus for my progressive scan DVD?
  2. mkjustuk
    mkjustuk
    Mar 4, 2002
    455
    Cheshire
    +14
    You can get 40" Acondas but they are expensive. A 32" is the next down and will blow you away. You can get the factory to fit a VGA card (50 quid) which allows you to then input a pro scan signal direct. There is a long thread about using the VGA board and Pro-scan - have a quick search for it and you will see what it can do.
