Loewe Vitros - Red diagonal lines running horizontally - HELP
Discussion in 'Televisions' started by vallii, Mar 24, 2005.
  1. vallii
    vallii
    Mar 2, 2005
    35
    Hello,
    My 32" Loewe Vitros 6381zw has served me well for about 3.5 years but recently red diagonal lines running horizontally across the screen and rising from left to right have appeared. These are obtrusive on a dark screen but invisible on a blue screen (like the Sky menu). Also the set flash's red for a second when the set shutsdown. I suspect this is a fault (and it's time for an engineer) but any help or suggestions would be appreciated.
    Irefan
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, are these 'red lines' gently rising from left to right and are there say 10 to 20 of them ? Are there perhaps more of these lines near the top of the screen than at the bottom ? Regards, yt.
