Loewe Vitros Progressive Scan Question
Discussion in 'General TV Discussions Forum' started by Buckster, Nov 30, 2001.
  1. Buckster
    Buckster
    May 21, 2001
    7,248
    103
    UK
    +370
    Sorry to ask what I am sure is a very stupid question, but I presume to be able to make use of the Progressive Scan/Proscan abilities of this TV (6381) with NTSC material, the DVD player has to be able to output in a Progressive scan mode ?
    Thanks for any help,
    Regards Mark.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Buckster:
    Not a stupid question at all! Unfortunately you are unlikely to get a definative answer from us or from Loewe at present.
    My findings so far are that, if the chassis inside the Vitros is creating a progressive image from the interlaced NTSC signal from a DVD player it is doing it badly.
    If you feed a progressive NTSC 480P signal in RGB to the optional VGA board you will get a superior progressive scan image as long as the DVD player is of a high enough quality.
    Gordon
  3. Lowrider
    Lowrider
    But still better than no progressive at all... :confused:
