Loewe Vitros and firmware upgrade
Discussion in 'General TV Discussions Forum' started by zoolap, Aug 1, 2002.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    Are there any firmware upgrades available for the Loewe Vitros - i'm hoping/wishing there might be one that gives you discrete remote codes for av inputs on uk models.
  2. Badger
    Badger
    Jan 21, 2002
    259
    First off - check which software and chassis you have (I think this is done by using the help button on the remote and then choosing technical spec).
    If you've got a Q2500 chassis then the s/ware will probably be as up to date as it's going to get for a while. Q2400 software varies from at least 1.2 (my system) to around 6.1 I think. I think that later revisions might help with discrete AV codes.
    The software on the set can be updated (I am currently aranging to have my Aconda s/ware updated to try to fix an NTSC display problem) - but i'm not sure on the costs/availability, if you use the UK contact email on the Loewe site then i'm sure they'll help you
    Phil
  3. magnatom
    magnatom
    Badger,
    That NTSC display problem wouldn't be moire effects at the side of the screen?
    I have this problem and I am waiting for someone to come from the shop I purchased it from to have a look. If a firmware upgrage would help (I have a q2400 chassis) then I could mention it to them.
  4. magnatom
    magnatom
    In fact I just checked our previous posts. I think you have a similar problem to mine. How does the firmware update help?
  5. Badger
    Badger
    Jan 21, 2002
    259
    I've just re-read your comments - my problem isn't Moire as it's too regular (compared to your description) IMHO.
    I mailed Loewe direct (Linn actually) and the guy there says a s/ware upgrade will help me so that's all i'm going on.
    Phil
  6. magnatom
    magnatom
    Ok. PMing you now.
