Loewe + VGA HELP!!
Discussion in 'General TV Discussions Forum' started by akash, Feb 23, 2002.
  1. akash
    akash
    Feb 15, 2002
    90
    London
    how do you connect progressive component (3 phono) from an arcam dvd player to VGA in loewe???
    do use a 3 phono to VGA lead??
    or do you need other stuff
    thanks
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
  3. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    Unless you get a converter that will change the component signal to VGA. Inevitably there is some loss in quality, which makes the whole thing rather pointless.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,412
    The Borders
    +3,229
    Gordon
    Loewe Aconda 93102 vs. Panasonic TH-42PWD4EX.
    Seems like Akash is having a lot of 'issues' getting the Loewe set up in his system - would a plasma not be a simpler option or is there a real picture jump with the Loewe.
    Joe
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
    Joe:
    I have discussed this with Akash beofre he bought the Loewe. I have yet to have any time with the 40" Aconda. I will soon. However, I feel that the image on the 42" D4 plasma in our dem room is far more watchable than that on the 32" Aconda's we used to use.
    This is probably due to the superior video processing we use inside the FMJ27 dvd player. I believe Akash saw a Panasonic and thought it too processed looking. Quite possibly it was not set up properly or they were standing right in front of it, I do not know. I suspect both can be pretty great. I'd have a plasma though.....
    Gordon
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Gordon: I'd rather have a projector. But hey that's just me!
    Have you seen the new NEC MP3? Meant to be a Panny beater.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
    Rick,
    I have a projector. But I'd only have one "I" thought was worth watching. It's easy to get BIG but not easy to get CLEVER.
    Gordon
  8. akash
    akash
    Feb 15, 2002
    90
    London
    thanks for everonr's help. i am still confused and i like both the plasma and loewe.
    also would a need a convertor to ibput the prog signal into the loewe vga?
    or is it as simple as using a lead.
    damn, plasma's are much more simplier
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
    Akash: I am unceretain at this time whether a transcoder would be required to send prog signal to the Loewe.
    I am pretty sure it will not work with prog pal though no matter how we send it to the thing.
    Gordon
