Loewe Tvs And Rgb
Discussion in 'General TV Discussions Forum' started by pauldarrington, Apr 7, 2003.
  1. pauldarrington
    pauldarrington
    I have been looking at the loewe aconda and verticos and have a couple of questions for any owners of these tvs. Firstly i currently have a sony fx66 and when putting my US consoles (XBOX, Gamecube, PS2) through RGB scart, the picture can be off centre but the sony tvs always have an rgb centering option so you can adjust the position of the picture. Now having played with the verticos for a time in john lewis i could find no such option so does that mean that the picture will be off centre or does the loewe handle this automatically. I am also wondering how well the loewe handles rgb signals, does it provide a good picture as i am also looking at a Sony FQ80 which handles rgb superbly.
    Thanks for any info you can provide guys.
  2. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    If the Articos is anything like my Aventos then it will have horizontal alignment adjustment but it isn't on the default menus; you have to go round the houses a bit! :p
    The RGB on my Aventos is better than my old FX66.
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    There is no "Verticos" but I assume you mean the "Articos" :).
    You will have no problems with RGB on Loewe televisions.
  4. pauldarrington
    pauldarrington
    sorry my mistake it should be articos. so you can adjust the position of the screen on the rgb channel ?
  5. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    On my Aventos you can :smashin:
