loewe tv differences
Discussion in 'General TV Discussions Forum' started by psalliss, Jun 19, 2004.
  1. psalliss
    psalliss
    Aug 27, 2003
    658
    Heysham
    +12
  2. psalliss
    psalliss
    Aug 27, 2003
    658
    Heysham
    +12
    can nobody help me with this??
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,976
    Galactica C.I.C.
    +291
    I click on the link you put in your post but is does not take me to any loewe sets to compare and help you with!
    What are the model numbers or names of the sets?
  4. psalliss
    psalliss
    Aug 27, 2003
    658
    Heysham
    +12
  5. Jack Bowyer
    Jack Bowyer
    The Planus 4781 is an old model with a non flat tube - its replaced by the the nemos now. The nemos is the only one in the range to have an integrated subwoofer so you would have to say the nemos is the best sounding one.
    Apart from that there the same (Mimo & Nemos) Nemos is alot wider with its speakers on the side.
    The Planus went about 12 months ago - they must still have old stock
    Note: the planus will have old software which will need to be changed to work with Loewe's upgrades. (VGA, Home lighting, 5.1 card etc)
    Hope this helps
    Jack
  6. psalliss
    psalliss
    Aug 27, 2003
    658
    Heysham
    +12
    cheers mate the mimo is probably the one i want then as i have a good 5.1 setup with amp.
