Loewe Teletext Controls And Advanced Controls Question.
Discussion in 'General TV Discussions Forum' started by Garrett, Jan 9, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    40,279
    2
    167
    The best thief you’ll never see.
    +6,682
    Just lately on teletext they have been mucking about with the fast text so if you are going through a group of pages instead of the green button being the next page on it has been taking you reader to pages un-associated with that ones presently reading.
    The question: on other TV’s I have had one of the buttons has been for the next page forward or back a page, but does the Loewe remote have this function?
    Also in the engineers setup is there anything like on monitors that they call pincushion? Where if the screen is something like a barrel shape or hour glass shape you just bring it back to square with one setting?
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    The Loewe Aconda does have the teletext Sub-Page feature that you are referring to Garrett - and very handy it is too. It should be activated as standard. To cycle through sub-pages just use the left/right directional button on the remote. To jump up or down pages, i.e., from Page 631 to 632, use the up/down directional button.
    The Service Menu parameter you need is "EW Amplitude" which stands for East/West Amplitude. This is equivalent to a PinCushion parameter on a Computer. There is no single button that returns the image to a perfect square and you have to adjust in units until you get it as square as possible. This should only be done on a Cross-Hatch Test Pattern screen, such as one from AVIA etc (seperate EW Amplitude setting for NTSC sources).
    The Loewe Service Menu gives you further control with EW Upper and EW Lower parameters as EW Amplitude adjusts them both at the same time.
  3. Garrett
    Garrett
    Apr 21, 2001
    40,279
    2
    167
    +6,682
    Thanks for the info, will try the second.
    But on the first I knew the sub page on but the up and down Key do you mean the the one on the circle with the big OK in the middle all it does on mine is high light pages that are available showing on that page then you press OK and you go to them.
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    I mean the one in the circle with OK in the middle. You could be right though as I never checked. Will take a look later for you though :).
  5. Garrett
    Garrett
    Apr 21, 2001
    40,279
    2
    167
    +6,682
    Was I right or have you found a way round it?
  6. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    You were right, the Up/Down buttons just highlight the pages within the text. I couldn't find any other button that will go up/down pages.
  7. Garrett
    Garrett
    Apr 21, 2001
    40,279
    2
    167
    +6,682
    I was going to say maybe you could program the programmable keys but they are the ones in use on teletext.:mad: :mad: :mad:
  8. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Briefly thought about that as well :). Teletext is a feature I never use anymore. It's strange as I was always looking up something before I got Sky Digital but since then, I couldn't be bothered switching to analogue channels to use teletext - lazy I know but you soon forget about Teletext.
