Loewe Spheros 32 HD IR Remote commands ?
Discussion in 'LCD & LED LCD TVs Forum' started by dambox, Jan 2, 2005.
Tags:
  1. dambox
    dambox
    I want to programme my remote controller. Does anyone have the IR commands from the LCD Spheros 32 HD they can post?
    Regards
    David
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Have you tried to remote control section or the remote central web site. Its standard Loewe TV codes but these do differ between US and European countries.
  3. dambox
    dambox
    Having spent some time on this today, what I specifically need to do is use a single discrete IR code to select the AV input - rather than press AV button and use the direction button to select - is this possible ? (no joy in the remote control section)
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    This has certainly been discussed in www.remotecentral.com - search the forums since the dawn of time. You need to watch out as some of the posints are for US models which are different to European ones.
    -Ian
  5. dambox
    dambox
    I have had a good long search and only came up with a single post that appeared relevent - I sent an email to the poster as no answer provided in thread. Will post back if any joy.
