Loewe PAL60 Progressive?
Discussion in 'General TV Discussions Forum' started by tommy, Apr 13, 2002.
  1. tommy
    tommy
    My understading is that when connection a component signal to the Scart3, you could get de-interlacing (100Hz) for PAL and internal progressive scan (60Hz) for NTSC.
    What about PAL60? Will it be de-interlaced or progressive scanned?
    Is the PAL vs NTSC really an issue for a component signal, or is it 50 vs 60 Hz that matters?
    // Tommy
  2. Steve1138
    Steve1138
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Do a search on these forums for "Loewe Progressive" and will find a number of good posts on the subject. It's still unclear as to whether or not the Loewe does actually de-interlace NTSC (or PAL) material. It does not do proper Progressive Scan for NTSC without feeding the Loewe a Progressive signal. This must be done through the optional VGA board on the TV.
  4. rbooth
    rbooth
    I got this from Loewe Germany when I bought my Xelos around a year ago.
    Dear Mr. Booth
    The Xelos with Q 2400 chassis has the ability to show a progressive scan
    picture with a interlace source. But only with NTSC-signals. The
    progressive scan processing is done inside the set but it is not possible
    to play with external progressive scan sources.
    Best regards
    Loewe Opta GmbH
    Service Dept.
    Michael Höfner
    Also check out the spec in the TV instruction manual which states:
    PAL/SECAM 100hz
    PAL60/NTSC 60hz proscan
    cheers
    Rob
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
    There is much more to this than meets the eye. We've covered this quite extensively on other threads.
    The Loewe's in UK have crap de-interlacing to create progressive image. They have no 2:3 or 2:2 pulldown detection to reconstruct original film frames from film based programme material. Using an external processor of some sort and the VGA input borad will bring the best results from NTSC DVD .
    Gordon
