I need some advice here
We're in the process of changing our complete system and while looking around my wife came around with the idea of getting a full Loewe system.
The system would be composed around the Loewe 42" Connect Full Hd Media DR+ with the Loewe 5.1 Sound and the Loewe Blu-Ray.
The complete system would be around 7000 (6200£) and this is causing me to have some doubts as I'm sure that with the same amount I can get some really high end stuff together.
I should be happy to have a lady that is proposing to spend this kind of amount and now I'm getting 2nd toughts
Do you think it is a good idea or do you see any alternatives? (maybe Pioneer???)
The main objectives are:
- Full HD TV 42" or 50"
- 5.1 Sound with small good looking speakers
- Blu-Ray
- Mediacenter to stream Music and Video from my NAS
- If possible DVB-C reception on the TV
Preferably the complete set from the same brand.
I'm not in a rush, so I can shop around and do some tests.
Thanks to you all
- Blu-Ray
Thanks to you all
