Loewe Nemos problem.
M
mickylee
Hi. First post from a techno thicko so please be gentle..
I've got a Loewe Nemos 32", bought new, which I've had for about 2 years.
For some reason I am getting a sort of smudging/delay on the image which is more pronounce on skintones.. I've not noticed this before, but now I have its driving me mad... I don't know if its in my head but it seems worse at night or maybe when the set has been on for a while...
Any ideas whats causing this? Whats the fix?
Any help would be appreciated.
0lly
I have an Aventos and I know what you are talking about. If you go into the picture settings from the menu I think there is an option called DNI or DNC. Turn it off and the image should improve. Those options are there to clear up poor images but do have a side effect of smudging.
Yes, this sounds like noise reduction being applied across the time axis. Turn off any NR options and the problem should go away.
M
mickylee
Olly, Lyris,
Many thanks.
There is both DNC and DNI I think, but I do know they are both turned on!!!!!!
I will toggle the other way and see what happens.
M
mickylee
Olly, Lyris,
Thank you both for your advice. It worked a treat and all is now tip top.
Thanks again
Mike
S
Sarah Nya
I notice that a lot as well, particuarly if it's a fast moving image.
Turn em all off I say, unless you're watching a bad quality TV and then it really does seem to clear up the picture.
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
