Loewe Nemos 32 Problems?
Discussion in 'General TV Discussions Forum' started by GalacticaActual, Jun 6, 2004.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Hello all.
    I am quite new to this so please bear with me if I make any mistakes.
    I am currently thinking hard about purchasing the new Loewe Nemos 32 T.v.
    I had a Sony kv36fs76u but noticed it had problems with R.G.B signals.
    I sold this tv and went for the 36" toshiba picture frame . This went back because of really bad bowing of the screen along the top of the picture.
    I then went for a Panasonic Tx36pd30 But that had a great deal of problems as well.
    I have recently seen the loewe nemos in action. I quite like this set but am put off by some people saying they can see strange moire patterens when viewing N.T.S.C signals. The Nemos I saw did not seem to have this but it did have a purple effect down both sides . This was caused by some speakers which the tv had been put next to in the past( acording to the sales man!)
    I did not get to see the tv in a darkened room so picking up any picture faults was difficult.
    I am very Intrested to know if anyone has had any problems with this set or one that is very similar, if these problems are easy to correct, how to get into the service menue to corect any bend or curves that the tv might have , and lastly what everyones generall opion of lowew tv pictures are.
    If I purchase this tv I will be using it for the following:
    Viewing sky digital via a pace digibox and R.G.B signal
    Viewing region one and two dvds Via a pioneer dvd757ai player and R.G.B signal.
    Watching videos with a jvc svhs recorder
    and using a playstation 2 with r.g.b signal.
    Many thanks in advance to anyone that can help.
    Dave. :)
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Is there no one out there with a Nemos that can offer me any advice?
    Would be very greatfull to any one that can help.
    I have tried searching the forum but no one seems to know a lot about this particular model.
    Are the codes to get into the service menu the same for most Loewe T.Vs?
    The reason I ask this is because you can get the set on line for less thab a grand and would not want the hassel of getting a enginner out if the only thing thats wrong with it is a slight geomatry problem.
    Many thanks.
    Dave. :)
  3. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    Hi davidsheekey,
    I not sure but I think the Nemos has the same chassis as the Adventos. Search on this model and you should be able to find out a bit more info.
    Bazza
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    many ,many Thanks, I will try that.
    I did hear however that the nemos had a totally new chasis and different firmware? if thats the word.
    will post again once I find out.
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Well,
    Tried to search for loewe adventos here and on google.
    Google thinks I am looking for loewe adventures!!!
    Av forums just brings me back to this thread.
    Thanks for replying anyway bazza , It is still recived with thanks!
    I have now ordered the nemos from tv and video direct.
    I got it for £950.00 including delevery. I should get it friday, and if anyones intrested will post some thoughts on it on this thread over the weekend.
    I am still after the service code for this model though so if anyone can help............
  6. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Sorry for posting yet again.
    I have an issue with noticing a pink tinge to the sides of the picture on a loewe set. I saw it on one ( the nemos) in a hifi shop and they said it was nothing to worry about because it had been next to some speakers.
    However, I have done a very carefull search on these forums and have seen that some people with the aventos have also had this problem. Does anyone know anything more about this?
    Also searching for a loewe aDventos wont get you very far :laugh: :laugh:
  7. wadeall
    wadeall
    Im thinking about getting an Aventos. Would be interested to find outhow u got on with your Lowe and what you think the diferences between the the Memos and Aventos might be
    Wade
