LOEWE MIMO & VGA UPGRADE?
Discussion in 'General TV Discussions Forum' started by smack, Oct 25, 2004.
  1. smack
    smack
    Jun 30, 2003
    28
    edinburgh
    I have a Loewe Mimo with a VGA upgrade, the only reason I have the VGA upgrade is due to the fact that I needed an IR Link for my Toshiba DVD player, when I got the IR link I was also automatically given the VGA upgrade. Anyway my understanding is that the VGA upgrade allows you to use the TV set as a computer monitor, I have no intention of doing this and so the VGA card is redundant on my TV, can the VGA upgrade be utilised to benefit the performance of the television set without connecting a computer or will it always remain redundant unless a computer is connected?
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    As I understand it, yes you need to use a computer
  3. smack
    smack
    Jun 30, 2003
    28
    edinburgh
    Thanks for the reply.
