Loewe Mimo Or Cable Box Problem
Discussion in 'General TV Discussions Forum' started by smack, Sep 29, 2004.
  1. smack
    smack
    Jun 30, 2003
    28
    edinburgh
    Hi I have had my Telewest cable box connected by scart to my LOEWE MIMO for about a year with no problems, but last night I noticed that the rectangular TV information box that appears every time you change channels has moved slightly to the left, for the last year it has been slap bang in the middle of the screen now its edged of screen slightly at the left hand side in 16:9 ratio mode and appears off centre in any other mode, the Telewest Home page also displays this same problem, actual TV programs seem ok, does any one know what this problem is or how to re-centre the information box? Any help would be most appreciated!
  2. danburbridge
    danburbridge
    mine is off centre too - as is my neighbours - think they are just wonky by design( knowing telewest...)
  3. smack
    smack
    Jun 30, 2003
    28
    edinburgh
    Thanks for replying, yes you seem to be correct, I hooked up the cable box to my daughters portable and it is off centre on that too.
