Loewe Mimo 28 - Connection help for a newbie!
Discussion in 'TVs' started by Roobarb, Jul 27, 2004.
  1. Roobarb
    Roobarb
    Hi!
    My first post here. I've just taken delivery of a Loewe Mimo 28, and very nice it is too!
    I encountered an odd problem during set-up though. To give you the background, I have a DVD player outputting S-video via an S-video cable and a SCART adaptor plug (SCART output not available), and a Sky decoder outputting SCART RGB.
    No matter what I do, the TV's auto-connection wizard refuses to let me hook the DVD player up to AV1. It selects AV2, which is the only RGB input, and I need that for Sky!
    To get it to work, the TV thinks the DVD player is a VCR (And hence lets me use AV1), and that the Sky decoder is a DVD player.
    It all works and it's accepting the correct signals (RGB for Sky, S-video for DVD), but it doesn't feel right.
    Any ideas?
    Adam
  2. andi
    andi
    The TV doesn't know the different between a DVD and a VCR signal. If you're worried, select the "AV equipment" generic option.
  3. Roobarb
    Roobarb
    Righto - it is all working so I'll leave it at that then!
    Cheers!
    Adam
