Loewe: Memorising settings problem
Discussion in 'General TV Discussions Forum' started by Londondecca, Jun 26, 2004.
  1. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    One very annoying problem with my new Aconda is the default sound settings cannot me memorised. The problem is with the bass setting. The default setting is way to high for my liking and I need to adjust it every time the TV is switched on. All the other settings are fine after adjustment, as these are stored aside from the bass setting.
    Any ideas?
  2. Jack Bowyer
    Jack Bowyer
    Even when you store as personal settings ?
    I will check on mine when I get home
