LOEWE IR LINK question
Discussion in 'Televisions' started by bigtrak, Sep 1, 2005.
  1. bigtrak
    bigtrak
    I have a Mimo 32" and have seen that I can buy a IR Link - am I right in assuming that this would enable me to control my cable box or DVD player by using the relevant controls through the TV's sensor? If so how many boxes can I control? if its only one per IR Link can more than one be fitted? Also are they easy to fit.
    Thanks for your time
    Ady
