Loewe Individual
rods&cones
For those of you out there that are contemplating purchasing the Loewe individual 32. Be aware that it comes in 3 versions Individual 32, 32s, 32 Edition. All the stores I've visited seem to have on display the lower spec model 32. and the shop staff do'nt seem to be aware of the spec differences between the 32 and the 32s which includes image+ contrast panel and DR+ if required. So if you want these features ensure the assistant is aware of the differences in the range or you will finish up getting the model on display which is always the lower spec model. Life would be much simpler if AV departments gave their staff better product training, alas in this day and age that would be expecting too much..
Flappo
loewe are crap , simple as that
crap products
crap service
and crap design
bang & olufsen wannabees
ianh64
As far as I am aware, Loewe displays are pretty much spec them yourselves. When I bought my Xelos 2 years back, I was able to configure it from a set of options. Unfortunately I didn't realise that the Spheros bassalt case that everyone was showing was also optional otherwise I would have omitted that option ond gone for the Spheros instead.
I had options such as DVB-T/DVB-Sat, DR+, DD, Home automation, mounting options, (as I latter realised) case colours etc etc. Some were avaiulable as aftermatket fit, others had to be ordered at time of manufacturer.
Tek70
crap products
crap service
and crap design
Do you own or have you owned Loewe product?
It'd would be good to hear you justify the comments or are you just giving opinion without justification ?
Look forward to reading your reply on this forum.:)
Similar threads
