Loewe HDMI problems - help!
Discussion in 'LCD & LED LCD TVs Forum' started by AZS1972, Mar 10, 2013.
Tags:
  1. AZS1972
    AZS1972
    Feb 22, 2013
    5
    Am looking for some help - seeing strange behaviour.
    Loewe Individual 46
    Ps3
    Panasonic BDT500
    The TV has two HDMI sockets.
    Both are completely fine with the playstation.
    Neither will handshake with the blu ray or my receiver.
    I've tried "tricking" the ports by swapping cables over after the handshake with the playstation.
    I've tried changing cables and reversing their direction (the latter somewhat reluctantly)
    The composite from the blu ray outputs OK.
    Does anyone have any ideas please? So frustrating...
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,606
    The Borders
    +3,495
    Use the Composite signal to allow you to access the User menu for the BD Player and set its HDMI Out to 1080i or 720p and also ensure HDMI CEC Control (VIERA link) is set to Off – make the settings changes then power the TV and BD Off at the wall, install an HDMI cable between the BD and the TV and then re-power.
    If that works try the same with the AVR using something other than HDMI Out on the AVR to allow you to set its HDMI Input/Output to Passthru (no up-conversion).
    Joe
  3. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  4. AZS1972
    AZS1972
    Feb 22, 2013
    5
    Thanks for taking the time to reply Joe. I've tried exactly as you've described but without luck...I'm losing the will to live. I know the blu ray is OK - it's brand new and worked when I initially connected it. Also - the playstation works in both HDMI ports - so I can be pretty sure the TV is OK.
  5. raysgem
    raysgem
    Mar 8, 2013
    2
    I have the same problem, and I tried this ,but it is not work
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,606
    The Borders
    +3,495
    Have you asked Loewe if they have any firmware updates available for your TV?
    Joe
  7. CMcK
    CMcK
    Mar 18, 2003
    426
    Scotland
    +39
    Look under the support section on the Loewe UK website. Register the TV and see if there is a later firmware than the version on your TV. Does the Individual have an update via the internet option? Could be worth a try.
  8. AZS1972
    AZS1972
    Feb 22, 2013
    5
    That's the next thing to do... "SegaSaturn" ;-)
    The TV is as follows...
    DVB - 8.3.0
    Software - 1.5.0
    Information is on it's way to Loewe right now...
