Loewe Aventos
jpm61
Has anyone else noticed that about 2 minutes after you switch off the television via the remote that it kind of switches itself on again for a few seconds but the screen doesn't appear?
Does anyone know why this does this?, also I forgot to send in my registration form to Loewe and a message flashed up on the screen reminding me to do it!, how did they know?
Lester
I've got an Aconda and have noticed this too. However it only does it when the TV is switched off after midnight.
If it's switched off before midnight then the telly will switch itself on at exactly midnight for a minute then switch off ! There's no picture, just the red and green LEDs.
I thought maybe it was something to do with the TV accessing that days EPG info - which we don't get in the UK.
Doesn't worry me. I've had the TV a couple of years and still going strong !
C
crooksm
You're correct - it is the TV searching for EPG information. You can turn this off - if press 'I', go into the index and search for EPG it should bring up the necessary options.
65-inch LG C1 Review coming soon to AVForums
