Loewe Aventos and RGB
Discussion in 'TVs' started by Paperboy, Jul 3, 2003.
  1. Paperboy
    Paperboy
    Jun 24, 2003
    64
    In my continuing quest for a good picture on my Aventos 32" I have now (thanks to this forum) put my Sky Digbox through AV2 on RGB. However, I see in the AV set-up menu that there is an option for "RGB Insertion at AV2".
    What does this do and, under the circumstances, should I enable it?
  2. Mick da Miller
    Mick da Miller
    Do no enable it! What the Loewe will do, if you tell it there is RGB insertion at AV2, is automatically override all other AV inputs when AV2 is operational - in other words when you're wathcing SKY you won't be able to use anything else and when you turn sky on it will interrupt you watching a VHS or DVD. Dont' worry as you will still have an RGB picture though.
  3. Paperboy
    Paperboy
    Jun 24, 2003
    64
    Thanks Mick,
    I wish they explained these things properly in the manual or on screen.
    Perhaps the members of this forum should be in charge of writing manuals!:)
  4. ste1010
    ste1010
    Feb 4, 2003
    488
    Middlesbrough
    +13
    Hi Mick
    could you help with a a query I have with my Aventos over Scart AV connections and voltage switching.
    I have my Sky box connected to AV2 using RGB. I enable Voltage switching on both my Sky Box and TV. When I powered Sky on my old TV used to switch to the AV input for Sky.
    My Aventos does the same, however when I then select RF channels the TV displays a graphic showing the channel number and then AV sound. The picture remains the Sky picture and not BBC1 for example. This happens with the RGB Insertion at AV2 both on and off. The only way to view an RF channel is to turn off the voltage switching.
    Could you advise how to set it up such that when Sky is turned on it jumps to AV2. But when another channel is selected that channel is displayed.
    Or is this not possible.
    Cheers in Advance
    Ste
  5. Mick da Miller
    Mick da Miller
    I'm pretty sure it isn't possible actually. I have voltage switching turned off and just press the '0' button to gt to the AV options. Sorry!
  6. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Correct ;) :).
  7. Mick da Miller
    Mick da Miller
    Looks like I'm improving paul! The wheel has come full circle and all that.:laugh:
