loewe aventos 28"
Discussion in 'General TV Discussions Forum' started by rickp, Oct 20, 2003.
  1. rickp
    rickp
    Hello,
    last weekend i bought a loewe Aventos 28". So i have a question about the picture settings.
    There are 4 settings, 16:9, 4:3, Pan, Zoom.
    When i choose zoom you can't see a part of the picture up and down. So i can't see the ?subtitling?
    When i choose Panorama i have got black bars on each side (which are not straight!!).
    When i choose 4:3 i have the same bars, only bigger (offcourse)
    So when i choose 16:9 the whole picture is filled up now. So i think this is the best option, but when i choose this option and i switch to another channel, the 16:9 setting is gone and it went to his former setting...
    How have you dealt with this problem?
    Because a friend of me has a philips tv and it can set to zoom automatically. With this setting he always fills up the whole screen..
    I hope to hear from you soon.
    grtngs
  2. rickp
    rickp
    HI,
    I cannot believe no one has experience this before...
    What are your opinions?
  3. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Impatience will not win you any friends.:rolleyes:
    Some of us have do have jobs you know.
  4. rickp
    rickp
    You are right!
    I am just so curious about the solution...
  5. ste1010
    ste1010
    Feb 4, 2003
    513
    Middlesbrough
    +20
    The Loewe picture format by default is either PAN or Cine, I cant remember now which it is. Myself and a number of other people asked this question some time ago and I contacted Loewe. I was told it is possible via the service menu to select 16:9 as the default so that this will be the format everytime the set is turned on. (this was on the 32" Aventos) If you do a search on this forum you should find the answer. I dont have the email any more I got from Loewe so I cant post.
    Also I would make sure you are comfortable changing any service menu settings.
  6. rickp
    rickp
    Yes i already switched it on. It was byte 3/0 change it from 0 to 1.
    My tv is now default on 16:9.
    thanx
