Loewe aspect ratio switching
Discussion in 'TVs' started by kwangomango, Aug 19, 2003.
  1. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Is there anyway to stop my Mimo from auto switching aspect ratios. I have disabled scart voltage and AMD but still it changes. During add breaks it sometimes switches ratios a number of times. My old Tosh had had the option to select auto aspect ratio ON/OFF.
    What exactly is AMD supposed to do BTW?
    Thanks.
  2. Badger
    Badger
    Jan 21, 2002
    257
    Are you using digital TV or analogue ?
    Is it switching between 4:3 and 16:9 ?
    Is it mostly on channel 4 ?
    Are the ratios changing sensibly ?
    If you're on analogue and channel 4 then they transmit some stuff that the Loewe detects as PALPlus and zooms the image in automatically - if this transmission flag varies then it would account for the aspect ratios changing
    If you have digital then channel 4 sometimes switch ratios between the program and the adverts (eg friends is 4:3 and the bumpers are 16:9 then the adverts might be either/both)
    AMD is meant to cleverly detect letterbox material and zoom it automatically to an appropriate level - I turned it off as it didn't seem to work too well for me
    Otherwise you could have a problem with your kit - are the scart plugs firmly in ?
    Phil
  3. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    I am viewing using $ky digibox and Freeview digibox. The set is sensibly switching ratios but i thought there was an option to disable this. I don't like it when a program is in 4:3 and the set switches to 16:9 for the ads and back to 4:3 after the ads. I suppose i could switch off the aspect ratio signal at source but was wondering why i can't get Mimo to ignore it.
  4. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    The set is correctly adjusting ratios from dvd source via scart. Is there any setting to stop this so that i can adjust the ratios manually?
  5. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    No, but I could tell you how to do it in the service menu if you want?
  6. whitcat
    whitcat
    Jul 19, 2003
    36
    SW London
    As a newbie I don't mean to hijack this thread but please can someone answer another Loewe aspect question.
    I have been thinking of the Aventos 3981 and found the specs to list five picture modes: 16:9, 4:3, Panorama, Cine and Zoom. I was worried that no 14:9 mode would be a problem. However, I looked at one today and the Panorama mode seemed to most closely resemble 14:9. There did seem to be a bit of horizontal stretching that I don't like though. Is is possible to adjust the picture (possibly via the service menu) so that it is a little less wide? I presume that the AMD only selects one of the five modes.
    It did seem much better than Sony's Smart - I really don't like that mode as it is too stretched (though some Sonys only seemed to stretch the edges while others did the whole picture).
    I plan to watch most material through Telewest digital so I would appreciate good auto-switching.
    Also, what is the Cine mode for? It seemed to be somewhere between Panaorama and Zoom.
    Thanks,
    James
