loewe articos
Discussion in 'General TV Discussions Forum' started by tmcevoy, Aug 30, 2003.
  1. tmcevoy
    tmcevoy
    I have a Loewe Articos and a Denon 2900 DVD player and am wondering what is the best cable to connect them
    At present I am using QED scarts but have found an old thread that suggests the QED AV2930 (component to scart)
    I have SKY+ on a normal QED scart as well but I understand the Articos only has one component input (av3)
    Any suggestions would be appreciated to get the best picture possible
    Tony
  2. tmcevoy
    tmcevoy
    What I mean is should I be using a box like Keane do or should I use a special QED lead
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    If your Denon 2900 has RCA Component ouputs, then you would benefit from using teh QED AV29 cable and setting your Articos AV3 to YUV (Sync on Y). Certainly it is my experience that Component gives the edge over RGB on Loewe televisions but the difference is slight. Others have said they prefer RGB.
    The QED cable doesn't do any RGB to Component conversion though so if your Denon only has RGB Scart output then use this instead. It would not be worth going through an RGB to Component transcoder from the likes of Keene.
  4. tmcevoy
    tmcevoy
    The Denon does have component outputs so I'll try that cable then , it was just sevenoaks suggested component out of denon to switching box then box to articos via scart
  5. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    There is no logic in that suggestion :confused:. Your Denon outputs Component, the Loewe accepts Component - no conversion needs to take place. Use the QED AV29 cable available from hificables.com.
    For Sky+, I would just use RGB Scart to AV2 on the Articos.
  6. tmcevoy
    tmcevoy
    Thanks very much I'll order one of those
