Loewe Aconda??
Discussion in 'General TV Discussions Forum' started by grufti, Apr 23, 2001.
  1. grufti
    grufti
    I'm just about to buy my first widescreen TV. I like the look of this model, but can anyone vouch for it's abilities, or should i be buying something else in the £1,500-2,000 bracket instead??
    :confused: :confused:
  2. Mossman
    Mossman
    Go for it mate! I have the 32" Zelos and it is superb!
    Cheers,
    Mossman :D :cool:
  3. Garrett
    Garrett
    Apr 21, 2001
    43,658
    2
    167
    The best thief you'll never see.
    +8,416
    See my letter in Which 36"TV.
    Sounds good as well.
  4. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    its probably the finest around at the moment,ive been saying that ever since it arrived.
    however, if you can wait and afford it,wait for the 40'acconda due in sept.
    if you want this tv look to pay £1690 minus stand.
  5. Napoleon
    Napoleon
    Jan 1, 2001
    The Aconda in september will in fact be a 38" direct view model,without a flat screen.The price will probably be frightening.
  6. grufti
    grufti
    thanks, I'm defo gonna get a 32", I have a small room and the 40" would be overkill.
    Superfi in Manchester offered me one for £1,700 straight away without trying to haggle, if anyone knows of cheaper please let me know.
    Grufti
    :rolleyes:
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Is you are into PCs make sure that you get the VGA option. I use it to connect an HTPC and the picture quality is superb.
  8. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Garrett you sent me a private message, but you have barred private messages and email so I can't reply. The answer is yes I have the same problem, but it doesn't affect me anymore because I use the VGA input for playing DVDs and the aspect on VGA is fixed to widescreen.
