Loewe Aconda Stands
Discussion in 'General TV Discussions Forum' started by lloydo, Jul 15, 2002.
  1. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    Could someone tell me what the minimum width for a Loewe Aconda stand could be.
    I'm limited for space so if someone could measure the base width for me I would grateful.
    I like the arca furniture/stands with the mesh doors (hides away gear but allows rc's to work) but they are 540mm wide or 990 wide and I want something in between, about 700mm.
  2. PeteMan
    PeteMan
    Measured my Loewe Aconda Glasrack and it's precisely 70cm wide. And a very nice bit of kit it is too.
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    As PeteMan says, you need 700mm only. The front base of the Aconda is approx 700mm with the back base being less. The Aconda has 4 rubber stud feet on it's base and these are actually a few Cm's in from the base so strictly speaking, you wouldn't even need a full 700mm in width.
  4. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    Thanks boys
    Groundy you are wealth of info about the Aconda........
    There are pro's and con's to the Loewe glass rack but I would like to have 3 shelves if possible and hide the equipment away.
    What other stands are people using for Acondas apart from the Loewe Glassrack?
    If Arca did a 700mm wide stand it would be perfect.
