Loewe Aconda HDR+
Discussion in 'General TV Discussions Forum' started by Dagwood, Jul 16, 2004.
  1. Dagwood
    Dagwood
    I've posted this on the DVD recorder site with no replies so far so thought I'd try here as well.
    Just bought an Aconda HDR+ with integrated hard drive for recording Tv. The manual says you can archive to VCR or a DVD burner. The menu only allows a VCR to be selected--any thoughts on how you might burn to an external DVD writer? There are several output terminals but I'm not sure what to do :
  2. Shin Gouki
    Shin Gouki
    Does your TV have progressive scan?
  3. Donos
    Donos
    Jul 5, 2003
    80
    Dublin
    I have Articos HD/DR+ and have configured "AV connections" to think it has the following SCART-connected devices :- AV1 = VCR ... AV2 = DVDR ... AV3 = DVD.
    In reality, I have not connected a device to AV2 yet (still saving up to buy a HDD/DVDR unit) ... but having configured TV as above, HD/DR+ menu allows me to choose to record to one of three destinations :- Internal HD, external VCR, external DVDR.
    As I said, I've yet to buy and then attach an external HDD/DVDR unit to AV2 to prove all works as expected ... but at least the menu options give me the choices I was expecting.
  4. Jack Bowyer
    Jack Bowyer
    You use AV3 scart but make sure you have it assigned in connections under "DVD recorder" or else none of the features will work
  5. Dagwood
    Dagwood
    Donos: I followed your suggestion and guess what --I have DVD burning capability as you described! :thumbsup:
    Now to connect up to an external DVD writer or my PC? Anybody any thoughts on the best solution ?
    Shin: Thanks for the reply--I'm not sure if it has that capability
    Jack Bowyer: Thanks for following up--the wizard in the Loewe assigns the DVDR to AV 2 so I guess that's the one it will be.
  6. Donos
    Donos
    Jul 5, 2003
    80
    Dublin
    As I understand it, the Aconda's AV Scart sockets are your only option for external record / copy (from internal HD) operations. This would suggest that if you plan to use external device with non-Scart connection you will need an appropriate Scart converter / adaptor cable.
    Nor sure what interface your DVD writer or PC supports, but suggest you start looking somewhere like Keene electronics catalogue (www.keene.co.uk) for Scart-to-ANother adaptor to match your external device.
