Loewe Aconda 9381 ZW Problems (Need Advice)
Discussion in 'General TV Discussions Forum' started by willhourihan, Oct 10, 2001.
  1. willhourihan
    willhourihan
    Hi all
    I recently purchased a Loewe 9381 ZW. It looked great in the show room but I am now discovering problems.
    The first problem is:
    When I watch a programme on TV if there are quick scene changes I get vertical lines appearing on the screen for a split second. This also happens while watching a DVD e.g. ‘Dinosaurs’. When the meteors are crashing all around with a lot of explosions, the vertical lines appear quiet a lot. This is starting to get annoying and embarrassing as I spent £2,500 IR on this set and I expected a little more from it.
    The second problem is:
    The picture is a little dark. When I up the brightness I can see, what I call residue from the last scene still on the screen. This is also starting to annoy me.
    My question is:
    Are all the above problems a fault with my set or is this just the way this set is?
    Should I return the set to where I bought it and ask for my money back?
    I have been emailing Loewe again and again and I have received no response. Looks like they don’t care! What do you all think?
    Thanks in advance
    Will
    [ 10-10-2001: Message edited by: IRL_Will ]
  2. gary.
    gary.
    Hi.
    Sorry to hear about the problems.
    I use my Aconda for watching Dvds so I can
    not comment on the scene changes.
    I will borrow a copy of Dinosaur R1 in the
    next few days and take a look,to see what mine does.
    As for Loewe not helping try this number, the guy was really helpfull when I called.
    01292 471552
    Let me know how you get on.
    hope all is sorted soon
    Gary
  3. gary.
    gary.
    Hi.
    I have just watched Dinosaur with
    no problems.
    Have you tried turning of MMI?
    If you like I can mail you my picture
    settings?See if that helps.
    Later
    Gary
  4. willhourihan
    willhourihan
    Hi Garry
    If you could do that for me it would be great.
    Will
    P.S. I have ranked you tha highest.
  5. gary.
    gary.
    Hi.
    Here are the settings that I use
    hope this helps
    Contrast 9
    Picture Adjustment Normal
    Colour 25
    brightness 25
    sharpness 2
    Tint 0
    DNC off
    DMI off
    AMD off
    Let me know how this looks.
    I have a mobile No of one of the
    service engineers if you are still
    have problems.
    all the best
    gary
  6. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    Hi Will,
    I also live in Ireland. I am looking at buying a Loewe 9381 ZW myself at the moment. I would be interested where you bought your set for £2500. I am in Dublin and have only seen it for approx £2,700 so far.
  7. encaser
    encaser
    Mar 15, 2001
    2,819
    Suffolk/Essex
    +740
    Lo guys, has anyone considered the new Aconda 9581? I saw it on the loewe.de site and it looks the biz. The only real dif from the 9381 appears to be "Full digitized signal processing 8 bits" so hopes of even stronger Sky/dvd viewing!? The word digitized does send bit (!) of a shiver these days when in conjunction with tv's processing properties though...
    And as Matt pointed out no black chassis.
    full translated addy is http://translate.google.com/translate?hl=en&sl=de&u=http://www.loewe.de/cda/products/daten/1,2295,ge-de-tv3-887-986,00.html&prev=/search%3Fq%3Dhttp://www.loewe.de/cda/products/date n/1,2295,ge-de-tv3-887-986,00.html%26hl%3Den%26sa%3DG
    It's on empiredirect.co.uk for £1850 inc del
    but a further £312 for glass stand. The T1 stand is even more - too painful to type!
    I want to see one of these bad boys in action but resellers seem thin on the ground.
    I've only found 2 sites selling them and empire is cheapest of them.
    Gerry, I had three Panasonic 36pg50's and know why you weren't impressed! So many 'faults'.
  8. willhourihan
    willhourihan
    Hi Gerry
    I bought it in Brown Thomas in Limerick for £2,450 although I didnt get a stand. The stand was a further £500. A little steep if you ask me.
    Will
  9. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    Cheers Will, thanks for the info. Lyric Hi-Fi in Duke Street in Dublin in were quoting me £2790.00 so it would appear you got a good deal. The stand was also an extra £500.00, way over the top although it is a nice looking piece of furniture. They also had another stand that had a built in sub-woofer but that was £1000.00.
    [ 22-10-2001: Message edited by: Gerry ]
  10. willhourihan
    willhourihan
    WOW!!!!
    Thanks a million Gary. Your changes have made the world of difference. I was getting a little worried by your settings when I read them first as my contrast was turned up to 58. When I adjusted it to your settings I could hardly see a thing on the screen, then I changed it to normal viewing mode as you stated and as if by magic the picture was perfect.
    A big thanks again!!!
    Will :) :D
  11. willhourihan
    willhourihan
    Gerry
    It might be worth your while to head down the country. Limerick is an hour from Thurles and I am about 1.5 hours from Dublin so it is not really a long journey if you could save nearly £350.
    Will
    [ 22-10-2001: Message edited by: IRL_Will ]
  12. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    Yes Will that's a good idea. Although I am going to check with BT in Dublin in the morning first. I know they have the Vitros but its £2500 and usually the Vitros is a couple of hundred cheaper than the Aconda. However if I have to go to Limerick I will, no problem.
    Cheers.
  13. gary.
    gary.
    Hi Will.
    Glad the settings made a difference.
    How amazing is the picture? =)
    All the best
    Gary
  14. willhourihan
    willhourihan
    Hi Gary
    Actually it's gone back to the way it was. The contrast always goes back to 50 when I turn back on the tv or move from normal viewing to day. Why is this do you think? It is unwatchable at the contrast setting you gave me. When I entered the settings and then turned to normal viewing the contrast goes back to 50 and vice versa.
    I only noticed this after I wrote the last message. So I am :(
    Actually I feel stupid for writing the last message as the the tv reverted to the way it always was and I didnt notice till tonight.
    If you could give me the mobile number of the engineers I would be greatful. By the way are they in the UK or Ireland. If there in the UK they will more than likely be no good to me.
    Will
    [ 23-10-2001: Message edited by: IRL_Will ]
  15. gary.
    gary.
    Hi.
    Sorry to hear the problems persist.
    Hear is the mobile no of one of the
    service guys 077994 70793.
    So am I right in thinking once you
    turn off the Tv you lose your settings?
    This is not a problem you can save your
    settings.
    Shall I have a look to see how to save
    them?I can not remember off the top of my head.
    All the best
    Gary
