Loewe A3781P aventos
Discussion in 'General TV Discussions Forum' started by 123orth, Sep 4, 2004.
  1. 123orth
    123orth
    Nov 29, 2003
    268
    leeds
    any opinions on this set,priced at 599.99 looked good for for 32inch 100hz sysyem
    if not this set then i would welcome recommendations in the same range 32inch/100hz telly preferably under 700 £
    would like to keep a budget of 300£ for home cinema system
  2. 123orth
    123orth
    Nov 29, 2003
    268
    leeds
    any other suggestions in same price range welcome
  3. andi
    andi
    Sounds like a good deal. Where are you getting it from?
  4. 123orth
    123orth
    Nov 29, 2003
    268
    leeds
    at empiredirect ,went to look instore did not have any but shows on their website
    any comments on the tv ,would it have ntsc playback
    how would it compare to newer sony for around 650£
  5. mgns
    mgns
    Feb 24, 2004
    155
    +17
    hi 123orth,
    i don't know much about the 3781 except that it has 2 scarts (1 RGB) compared to the 3 scarts (2 RGB) on the newer 3981. i also think the newer one may have virtual dolby aswell.
    have a look at www.loewe.de - it has an english translation option near the bottom of the screen - for tech specs and comparisons.
    mgns
