Loewe A32 - fix to 16:9 aspect
Discussion in 'LCD & LED LCD TVs Forum' started by s3marc, Aug 3, 2006.
Tags:
  1. s3marc
    s3marc
    May 10, 2005
    134
    +5
    I have tried to save user settings of 16:9 , but it never stays as this. it there a way of 'fixing' the aspect to 16:9 in the service menu (still allowing user overide thru the aspect settings). if I set the user settings to Zoom , it will always start in this mode, if I set it to 16:9 , it usually starts in 4:3 (source is AV2 - Sky (sky is set to 16:9) , and the source channel is usually a 16:9 , but the set still starts as 4:3)
    Any ideas
  2. s3marc
    s3marc
    May 10, 2005
    134
    +5
    In service menu select "Option Bytes", then "Option Byte 3". Change "Bit 0" from a "0" to a "1".
    !!Please be carefule not to adjust anything else while in service mode !!!
    Switch your set off at the mains and then back on again. This new setting should now be in place and result is that screen format default should no longer be recalled upon channel change or switch off and on
