Loewe A 32 settings
Discussion in 'LCD & LED LCD TVs' started by laurad, Jun 13, 2005.
  1. laurad
    laurad
    Hi all,
    two weeks ago I buyed my Loewe Xelos A32.
    Yesterday I tryed it, but I'm quite confused with image settings.
    The PQ seems to be good, but when last nigth I saw my football match and then a film, it seems that the faces of persons were not real.
    It's difficult to explaine: the color of the skin was too brigthness and thw white was too brilliant.
    Can someone help me and tell me the rigth settings?
    Thanks very much
    Laura
  2. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    May be you have discovered this already but nways if you havent, perhaps you could try setting picture adjustment to soft. Hope this helps.
  3. majdj
    majdj
    Try turning the contrast down - it's often set high for initial impact. Then adjust the colour down before trying the brightness. There's no set settings - your room (light/dark/big/small) will affect the picture.
    Just have a play around - if you don't like it, hit the restore factory settings to go back the start! :thumbsup:
